In the middle of first engine drop on 87 - not sure where I disconnect the G50 slave
Would love some beginner help if possible. Do I disconnect the hydraulic line from the car where it goes into the slave just next to the bleed screw? Or do I somehow unbolt the entire slave cylinder?
Attempting to drop 3.2 motor and g50 transmission at the same time.
Thank you!
Old 08-06-2022, 11:58 AM
Bentley to the rescue. Got it
Old 08-06-2022, 12:23 PM
Yeah, two nuts off and set it aside. Do it after you lower the engine a bit and lean over the top. assemble the same way. Tie the clutch pedal to the steering wheel.
206 637 4071
Old 08-06-2022, 06:57 PM
