Coram Deo
Installing AFR gauge while keeping Lambda
Good afternoon!
I was fortunate enough to buy a custom quad gauge from John Bell for my '80SC. It's all conceptually straightforward, but the difficulty is in the details, particularly the oxygen sensor wiring. Help me out here. So here is the wiring diagram for the Lambda system ![]() At Rob's suggestion, I have an Innovate LC-2 interface box. with the following wires to be connected. - Red to +12V, proposed terminal 30 on the frequency valve relay - Black to ground, proposed FRV relay terminal 85, (also to gauge?) (also to Lambda box terminal 2 or 4?) - Yellow (0-5 V) to gauge - Brown (0-1 V)to lambda box terminal 2 or 4.... This is where I am stuck. The wiring diagram shows the oxygen sensor connecting to the Lambda box terminals 2 and 4 through what looks to me like a coax cable. The LC-2 has a single wire for the low voltage output. - which pin should the yellow wire connect to, 2 or 4? - should something else be connected to the other, unused 2 or 4 pin, like a ground? - where is the best place to connect these wires? In the engine bay connector, or open the Lambda box connector somehow? You might get the impression I'm over my head, and your impression would be right. But I'm still having fun and learning stuff so I'll press on. ![]()
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio Last edited by RDM; 08-10-2022 at 07:59 AM.. |
For the O2 sensor Pin 2 is the signal to the control unit.
pin 4 is the shielding around the signal wire to cut down on interference in the signal. Pin 4 is essentially the ground connection for that shield. the Lambda control unit is expecting a 0-1 V signal (oscillating around 0.5). this would be the brown wire out of the Innovate LC-2. the yellow wire would go to the wideband display at the bottom of you new gauge. I don't know your layout, so can't say where the most convenient location to connect the wires would be, but you can connect the LC-2 brown wire in the engine bay at the original O2 sensor plug. if you do this the shielding would still be in place around the original signal wire, so you wouldn't mess with pins 2 or 4 at the control unit. |
In the innovate setup software you maybe have to change from "0.00 Volt" to "high impendance" output in the input field "Warmup output" – as the original ECU expects that from a cold state of an original non heated OX sensor.
911 SC 3.0, 1982, black, US model with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 08-08-2022 at 04:32 AM.. |
Coram Deo
Given the easy access to three of the four needed LC-2 connections on the left side of the engine bay, I am sorely tempted to put the LC-2 there, behind the plastic cover. Then, the only wire to run forward would be to the gauge. Or are conditions there too harsh for the LC-2? So under this plan, - Red to +12V, proposed to rear fuse box. I don't have a rear blower, so that's easy - Black to ground, proposed just behind the rear fuse box. I'm not clear if I also need to run this ground to the gauge, and / or also to the OXS coax shielding. - Yellow (0-5 V) to gauge - Brown (0-1 V)to lambda box. Does this particular connector have a name or known source? It's a one-wire connection as far as I can see, and I'd rather not cut the connector off of a perfectly good oxygen sensor. ![]() Quote:
I dread this as I don't own a Windows computer with a serial port, and I think that's what is required to change settings. The oxygen sensor input is ignored until the motor warms up- how does the oxs warm-up time compare to engine warm up time? Or is this a warm start problem?
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
the brown wire is an Analog Output. in this case you will be using it as a simulated narrowband O2 signal.
as for the ground locations, ideally you would add/extend the ground to all the affected locations, so one to the wideband mixture display gauge, and a second location at the Lambda control unit. Sorry don't know a source for the O2 connector. |
https://www.sip-scootershop.com/en/product/wire-brakeout-plug-1-0-2-5mm-cable-600v-105-c_10156400 Quote:
911 SC 3.0, 1982, black, US model with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 08-10-2022 at 02:48 PM.. |
Bookmaked
Thread Tools | |
Rate This Thread | |
