-   -   Rebuilding alternator - how do I get the back bearing out? (http://forums.pelicanparts.com/porsche-911-technical-forum/1124241-rebuilding-alternator-how-do-i-get-back-bearing-out.html)
BrakeL8 08-08-2022 04:57 PM
Is this Paris Rhône plastic piece a cap I remove and then press the rear bearing out? Can’t figure out how to remove this.
Thankshttp://forums.pelicanparts.com/uploa...1660003091.jpg
BrakeL8 08-08-2022 05:36 PM
Tapped it out with a 1” socket- it broke. Turns out my new slip rings come with a new one. Brilliant. (Used a vise to support the housing and very gentle tapping.
wazzz 08-09-2022 06:08 AM
It's a tight fit but it should have come out without breaking. When reinstalling, make sure you fit the new plastic cap onto bearing race first, then push them together into the alt body. Do not try to insert the cap first as it would break again or be damaged when pushing the bearing in.
