Oil level gauge stuck?
My oil level gauge seems to be stuck at 2/3 full scale, regardless of whether the ignition is on or off.
This started after I had just changed the weeping gasket on the oil level sensor. I did not have any trouble manipulating the sensor in and out, and of course, it is wired correctly. Any thoughts?
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
Maybe hitting the oil level stick
Tried that, no luck. Odd thing is that the gauge stays at 2/3 even if I disconnect the wires at the sensor. And I checked the sensor with a ohm meter and it shows continuity with resistance. Stumped.
Since the meter isn't zeroing out when ignition is off, the issue is the meter.
You can remove the meter from the dash, note the wiring with photos, remove wires from the back and remove the meter half (the oil level and temperature meters are separate devices) to see if there is something catching in the movement. |
Ok, looks like I’ll be pulling the gauge. Odd coincidence though.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Yes. Ignition off, key out, wires disconnected. So this morning I tried an old Cessna trick and tapped on the gauge. It returned to zero. So I’ll be pulling the gauge.
ok here is what happened....
when you were changing the sensor the gauge likely "pegged" to a position it is unnatural , and it did it very quickly jamming up the works.. i bet its fine after your tap.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I always question the accuracy of the gauges, especially these 45 yr old ones!
Finally figured out it was the loose wire connection at tank as the reason for the sporadic jumping oil level needle, and stuck on High too. But noticed the oil level dash gauge will stick to the top (full) high level whenever I check oil dipstick (half way mark, engine running) but dash gauge later will go back to low side of normal level, just a bit below the red bar. What would the dipstick be hitting inside the oil tank - the meter? |
I just replaced the oil tank sender, found a dip stick laying in there.
Solved
Solved
A PO added these cheesy little faux faces to the gauges. One had displaced enough to interfere with the needle. All fixed now, and I did the gas gauge as well. Now I am going to take the stuff off the other gauges, but how hard is it to r&r the needles on the tach, Speedo, and clock?
You will see an increase in level on the dip stick and on the gauge if the engine is checked just after the thermostat opens and sends oil up front and if it is up to 210 or 220. The hotter oil expands enough to change the level. When the engine is cold that oil gauge is to be ignored. And no if you are putting the dipstick down the little pipe, you are not touching the gauge float.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
There is a video by Nico at Charlies Foreign Car Garage for removing the needle from the speedo. As I said, not for the those without a delicate touch and a steady pulse.
____________________________ If it's not leaking, it's out of oel... |
The more I look at it, the more I think the fake facades are not glued on. So I think on the Speedo/tac/clock I can remove the two tiny screws and lift the facade up just enough to make two cuts with small scissors from the edge to the center (like a slice of pie) and then slide the two pieces out from under the needle. I may change my mind though when I actually have it on my work bench.
