911SC Seat Disassembly Question -
So the "INNER SEAT BOLT" on the passenger seat just "spins" - tried to find a photo as to "what" it is threaded into on the inside of the seat frame but not having much luck. Any photos/diagrams or suggests on getting it would be helpful.
Here's the bolt - https://www.pelicanparts.com/More_Info/91152137100.htm?pn=911-521-371-00-OEM&gclid=CjwKCAjw6fyXBhBgEiwAhhiZsg8LjwHZ4i4Ikq6erlvt 6IJL8omNrSDKC8UudBvPI91Aqu88nAWzrBoCDrsQAvD_BwE |
Loco... I think there is either threaded metal there and/or a welded nut on the frame. If the threads are stripped, you'll be able to grab the screw with vice grips or similar and pull the screw out. Pull needs to be straight out or the screw can bind and it will "feel" like it won't come out. If there is a welded nut that has broken loose and the threads are good, it will NOT pull out.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
