CDI replacement, battery disconnect?
Is it necessary to disconnect the negative on the battery when replacing a CDI unit, and why? Thanks!
PRO Motorsports
No.
There is no power to it with the ignition off.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
I’m not sure about the stock CDI but I’m pretty sure the MSD gets hooked up to a always hot. So if that’s the case then yes, disconnect the battery until the connections are all complete.
78 SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8 HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Coram Deo
The wire to the CDI is not fused.
I would disconnect the battery for any electrical work, as some of the things you work around may be powered all the time and cause you a little excitement.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
For example, if you dropped a tool onto the 3 fuses in the engine bay, they are all live with the ignition off and right next to the CDI unit. |
For security reasons - absolutely!! No excuses!
A CDI can produce sparks up to 40.000volts - they can flash over distances up to 15inches/40cm! This if life threatening! ![]() Trasnlated from Reparatur Bosch HKZ fόr Porsche 911 und 914/6 Thomas
1981 911 SC Coupι, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. Last edited by Schulisco; 08-25-2022 at 12:49 AM.. |
The CDI unit itself – where we are talking about here – does not produce the 40.000 Volts, it's the coil and even here the engine must be running to make the inductive signal from the dizzy let the CDI get triggered.
When ignition key is off there's no current provided to the CDI and it can be easily disconnected, but as a rule of tumb im totally with RDM and Jonny to disconnect battery on all electrical work – even when just working in the engine compartment.
911 SC 3.0, 1982, black, US model with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Coram Deo
I had a long misadventure with the instruments because I didn't disconnect the battery. You just need to accidentally touch that one wire on the back of the clock to something sensitive to cause yourself endless troubles. Learned my lesson.
