mint911g
911 head light switch fuse
Hello,
I burnt my head light switch on my 1976 911. I am awaiting a new one, and a relay, but am also planning on installing a fuse between the switch and the black/blue cable (instruments). However I cannot find any information regarding what Ampere fuse to install. Is anybody able to guide me on this? Thank you. |
I'm just doing this job too. I think that there are about 12 bulbs at about 2 watts each so that's a total of 24 watts. Dividing by 12 (volts) gives 2 amps maximum , so I have decided to fit a 5 amp fuse but interested to hear what others have to say.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
What I put in :
- 3A fuse on instrument lights (but probably bit high since I canged them to LEDs) - on term 58a of the switch - 3A fuse on terminal K of the switch to the ashray light
__________________ 1985 Carrera 3.2 |
A single 3A is good for all the dash/under dash lights. Connect one end of the fuse pigtail to the switch (58a) terminal and the blue/black wires that were on 58a to the other end. There should be two blue//alack wires on your '76. One to the heater/vent panel control lights, ashtray light and the temp control lever light and the other to the gauge lights.
If you want to add the third wire from 58a, it goes to the Hazard flasher indicator light (glows red).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 08-25-2022 at 07:59 PM.. |
Roy
On my factory diagram for '78, There should be no blue/black on K. Only a gray wire that goes to fuse S2 and then to the license plate lights. It is the same as my post regarding "76 above (unless there is something different for Europe).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
