Url Url is offline
Url's Avatar
Not enough clutch cable travel => Tips? Risk?
Hi all,
I have replaced my clutch, flywheel, release bearing, shift fork, clutch cable,... on my SC 1978.
After adjusting the clutch all seems fine (1.2 => 1mm at release lever, pedal feels good,...) but I'm unable to attain 25mm of clutch cable travel.
I have adjusted the rubber stop to the max position but I'm only getting 23,5mm.
Any tips on how to get to 25mm?
What is the risk of driving with considering the clutch does not slip? Premature wear on the clutch release bearing or anything else?
Old 06-13-2023, 10:36 PM
You might not be able to get to 25mm. These old cars are no longer in spec. Take out the free play at the clutch release (meaning adjust out the gap). Also a new clutch needs to wear in a bit to drive well.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-14-2023, 06:08 AM
Setting Up Clutch Cable Adjustment…….
Did you try to do the cable adjustment at the clevis end? How many mm is the nut from the tip of the cable at clevis end (clutch pedal end)? Could you post some pictures? Thanks.
Tony
Old 06-14-2023, 06:28 AM
Url Url is offline
Url's Avatar
Free play is gone, clutch works well.
Does the thread at clevis end influence the cable travel? I thought it only influenced the free play at clutch arm ...
Old 06-14-2023, 10:23 AM
