G50 input shaft identification
Little help?
Been collecting factory G50 gearsets for a good long while now, hopefully I'm almost there... I have this G50 13:41 input shaft & gearset, clutch side shortened (eg for SBH). It was originally (mis)labeled as being a G50/50 input shaft - but the internal shaft is too short for that application and bearing spacing is incorrect. So I'm hoping that this would fit a G50 N/A 5 speed (like my SBH G50/01). I know there were some 13:41 shafts for the 993 RS G50/2x 6 speed, Roger of CMS already told me that these aren't what I want. Can anyone tell which this is by looking at it? In case these are anything other than batch/manufacturing marks, it is stamped "G" by the 1st gear, and scribed "35" about 90 degrees from that. Thanks for any insight! http://forums.pelicanparts.com/uploa...1661786231.jpg |
I think you’re dealing with a shortened shaft.http://forums.pelicanparts.com/uploa...1661815150.jpg
Far left is turbo. Just left of the tape is shortened turbo. Right of the tape is g50. I don’t have the other end of the shaft handy to give you a total length, but could get that tomorrow. If it’s not a shortened turbo shaft then it will be a G50-02, which was used in a couple cars. |
I assembled and measured one this morning, and it's right around 25.5" Are you sure that's been shortened? How does it measure tip to seal compared to the shafts I posted above. It looks around 4"s similar to my short one.
What does it measure from the clutch end tip to the threads for the first nut? |
Hey Matt, thanks for replying/helping.
For the 911, I get folks who know what they're doing to work on them... I'm pretty sure it has a 13:41 gearset, because I counted the teeth. Twice :D And it looks like other G50 shafts I've seen photos of. So fairly confident of that, too. It is supposed to be shortened; originally described as "shortened G50/50" (probably because of the gearset) - but a Pelican who wanted exactly that reported that it wasn't a /50 shaft, based on it being too short internally for the bigger /50 C&P/intermediate case. Seems likely they made an assumption based on the 13:41 gearset. So I bought it, as SBH G50/02 shaft exactly what I want. Not even much of a problem if it isn't shortened - although overall length seems to suggest it may be? Quote:
http://forums.pelicanparts.com/uploa...1661954349.jpg http://forums.pelicanparts.com/uploa...1661954369.jpg http://forums.pelicanparts.com/uploa...1661954369.jpg |
http://forums.pelicanparts.com/uploa...1661962388.jpg
Always happy to help when I can. That was the picture I was looking for. This is just a regular G50. Shortening takes it down by 1.1”, so yours just shy of 11” is right compared to my 12”. I agree it’s a G50/02. |
That 3.154 is a nice ratio. It’s the only thing I make for stock these days.
| All times are GMT -8. The time now is 09:40 PM. |
