-   -   Mixture settings CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/112558-mixture-settings-cis.html)
mb911 05-28-2003 07:49 PM
I was reinstalling my fuel distributor tonight and noticed that there is no plug where you adjust the mixture should there be?I would assume that could be some sort of mixture problem? Vacum leak? Just want to know before I continue on.
Ben
MotoSook 05-28-2003 07:55 PM
Not a problem, just a small bit of dirty air by-passing your filter...does not affect vacuum or mixture...It'd be nice to have one, but I don't run with one...
dean 05-28-2003 08:08 PM
On my 930 motor leaving the plug out does mess up the mixture. The CO goes from 3% plugged to 1% unplugged at idle. So I plug mine
mb911 05-29-2003 04:01 PM
Thanks for the input just trying to figure this stuff out. I kind of like carbs better and better.
Ben
stlrj 05-29-2003 05:16 PM
But on carbs you have six mixture screws, sync adjustments and in CIS only one.
What could be simpler?
Joe
mb911 05-30-2003 04:30 PM
Yes but carbs are easier to do diagnostics on. I know the mixture screw deal. I have spent many days full ones at that setting my 914-6 up for different weather.
Ben
47silver 05-30-2003 07:41 PM
pelican sells the plug i bought one
gar
mb911 05-30-2003 07:58 PM
Does it make a difference? I just can't imagine running this fine of a car with dirty air flowing through it.
Ben
