porsche 901 gearbox with pullclutch vs vw type 4 possible?
is this possible i cant find any info. and sourcing an pushclutch gearbox is not an option
can it be converted or is there any other flywheels i can buy to run the pullclutch?
Behind the Sun
No comprende
Tell us just what you are trying to do. What is the application?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
It's a 914 ...
Perhaps you are asking if the 70-71 push style clutch from the 911/901 trans can be used with a VW?
If so ... Porsche never mated that to a VW to my knowledge. The trick would be getting a flywheel to work with that setup. The flywheel would look like a 70-85 911 flywheel but with a VW mounting hub. Kennedy might be able to help? But it might be easier to figure out how to use the 914/earlier 911 style 215mm clutch and figure out how to make the clutch cable arrangement work. 914s had a pulley on the trans, for example. |
69 was the last year to use a pull clutch and used the same spline on the output shaft that a VW transaxle used. Should work on a type IV engine with the stock flywheel clutch set-up.
The 914 used a version of the 901 transaxle, so I would check out the part numbers for the PP, clutch and TO bearing. Last edited by SWS911; 09-01-2022 at 05:58 PM.. |
Under the radar
I imagine Kennedy Engineering or Patrick motorsports may have a custom flywheel and pp assembly that will mate most combinations.
69 used a PUSH clutch. Not enough meat in the 70/71 bellhousing to mount a early pivot ball in the proper position, which is different than a 70/71.
I'm lost. Are you saying you want to try and install a VW engine\transaxle? You really need to clarify if you want any sort of intelligent response..
Gary R. |
I want an type 4 on the 901 gearbox, engine fits but cant solve the clutch |
I've got a 69 912. Years ago one cylinder of the engine ingested the fuel enrichment nozzle from one of the carbs. Engine came out and torn down. In the meantime, my dear friend the 356/912 guru decided he'd like to buy my car. Instead of rebuilding the 912 engine, he installed a 70 or 71 911 4 speed transmission to replace the 5 speed 901 transmission, and installed a VW Type 4 engine. I've since reacquired the car with this set up but it is distant to me so I couldn't tell you what is what at the moment. But that was one resolution of putting a type 4 engine in a car that had a 901 transmission.
My Type 4 engine is a later 2.0 liter variant with a single center mount carb system. It moves the car down the road but wouldn't spin a wheel from a standing start on a month old dead banana. Last edited by SCadaddle; 09-02-2022 at 01:03 PM.. |
#147 of 2096
Contact Kennedy Engineering,
They have the flywheel that you need. Either for VW type 1 or 4
#147 of 2096 |
It wouldn't work with a '70/71 transmission, as others have noted. Last edited by Daves911L; 09-02-2022 at 08:28 PM.. |
It's a 914 ...
A 914 flywheel will get you what you need, they had the exact setup you are looking for (pre-70 911 clutch + 901 trans).
Careful to get the right flywheel though, needs to be 914 not just any type 4 that takes a 215mm clutch. I understand the VW type 4 flywheel has a different offset than the 914 one, and won't fit a Porsche gearbox. |
Here's a chart of the transmission numbers. I'm pretty sure the 4 speed box that was retrofitted to my 69 912 was a 911/00 4 speed from 1970 because I remember thinking "wow that's a pretty rare bird by the production numbers (only 690 total?)". I'll see if I can dig up some photos.
901/13 gear question See post #5 by Early S Man. Last edited by SCadaddle; 09-03-2022 at 07:14 AM.. |
Hi just to say, incidentally Im planning the fitting of a
Into a 1979 911SC also while I work (and take my time) on the 911 engine. To make it work, you need a
and for me I have an SC
All of that said I only did a trial fit with the 902 transmission and a type 1 1600 engine which I borrowed off a freind. It fitted up and while I made it run, I ignored the clutch and driveshafts at the time. I have yet to put it all together with the full set up based on the type 4 as I have since decided that the body is more important! I will come back to the 902/VW when I finish the body so I can drive the car while I work on the 911 engine. Realistically that may be a while. Last edited by strictly; 09-03-2022 at 12:26 PM.. |
Eng-o-neer
This is a bit silly. Just buy another 2.0/2.2/2.4 engine, run it, then sell it for what you paid for it after the rebuild.
Or, buy a 3.0/3.2 in good shape and put your 2.0 under a bench, because it's more expensive to rebuild properly than a newer engine costs outright... |
I agree though In fact my preferred route for ME would be a spare 3.0 SC engine, as I want to experiment on EFI/ITB and be great to set that up on an "old engine" rather than a freshly rebuilt engine and have problems with breakin, by too much tuning while getting it to run. So for sure I have 1 eye on the ground for a spare engine, but as I have a 902/14 trans sitting around from another project, and only shelled out £350 for a complete VW Type 4 engine also it makes for a conversion less than £600 - 800. For sure and myself included, no one really wants a 4 cylinder in a 911, but at the very least is saves some money on gas which I can put towards EFI/ITB/motor rebuild. A US gallon (3.8 L) in the UK is $8 a gallon(!), and that is not even the really good stuff! In the UK our "gallons" are 4.54 L Last edited by strictly; 09-03-2022 at 12:48 PM.. |
