Ti Lug Nut Non-Marring Socket?
What socket are people using to install titanium lug nuts without marring the finish?
I saw the Stoddard socket but read it causes damage. I also saw where people used an internally nylon / delrin lined socket but those appear to be unavailable anymore. I’d like to find an internally nylon lined 19mm socket unless there’s some other option I’m not aware of. Thanks in advance for the help. Stretch |
There are cheaper ones out there but Wera is a good German brand. I have a full set of Wera lug nut sockets and am very pleased with them. Only use with hand tools. Air tools will destroy the plastic.
https://www.kctool.com/wera-004590-lug-nut-1-2-impact-socket-with-plastic-sleeve-19mm/ Google search for 19mm sockets. Whatever you choose, read the description to ensure that the socket has an internal protective insert as well as the protective outer sleeve. Some just have the external sleeve. https://www.google.com/search?q=plastic+coated+19+mm+lug+nut+sockets&ie=utf-8&oe=utf-8&client=firefox-b-1 Last edited by ChrisHamilton; 09-07-2022 at 05:41 PM.. |
I’ve been using the Hazet on mine and haven’t had any issues over the last 5 years. Most important is to take your time when sliding the socket on the lug.
CURRENT: 2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black 1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue 2024 Macan White, Beige / 2010 Cayenne White, Black PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey |
i have been using these ..one is aluminium and the other with hard plastic inside
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks for the leads. The Wera is out of stock as a single 19mm everywhere I’ve looked but I’ll keep looking. The “Sof-tite” option is also an older tool so I’ll do some research and see if I can find one.
Stretch |
Aluminum socket here. No problems / marring with multiple on / offs with several sets of black Ti open end lugs.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Red Line Service
If you take a look at my podcast "Marc Bixen Live" episode 3 "Goin Invitational" at the 10:00 mark we provide a "Tech Tip" for this situation!
https://www.youtube.com/watch?v=OayERa1Xbis
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
Ivan
