 Steering rack rebuild Can someone help me find someone good who could rebuild the steering rack on a 3.2 carrera.  Cheers |
 Long way from Florida to Canada. Where are you? |
 Westchester NY |
 Shawn at true6 will do it. He’s in Mass |
 Not a hard job at all…diy.  Seriously, disassemble, degrease, diagnosis and repair, replace a few seals after re-greasing and reassemble.  Seriously it’s only a few hour job once on the bench. |
 Just here in case any useful rebuild threads pop up... |
 I rebuilt my own steering rack on my '84 911 a few years back. There was only one worn piece in it. I had a friend machine one out of self lubricating brass and it's been good every since. This is the worn piece. http://forums.pelicanparts.com/uploa...1663103929.JPG |
 On my rack there’s play in the steering arm shaft. The mechanic and I pulled the tie rod boots back, went ahead and grabbed the shaft going up and down and side to side and it has play. Not sure if there’s bearing or seals holding the shaft in place.  What are your thoughts? |
 I don't have one of those. He moved. |
 Can I pull out the steering rack with the crossmember in place? |
 Anyone know the thread pitch on the two M10 x 45 steering rack bolts?  1.25? or 1.50? Certainly not 1.0. |
 Almost certainly 1.5. I think the parts catalog is usually pretty good about calling out non-standard thread pitch for fine thread bolts. |
| All times are GMT -8. The time now is 10:38 AM. |
