Automotive Monomaniac
Emission's Avatar
Originally posted by tholyoak
Personally I would suggest before you get too worried about your temps, checking for an electrical problem based upon the fact with ignition in the on position and the car not running you have a reading of 3.5 bar on the oil pressure gauge. Obviously you should have a reading of 0 if everything is hooked up OK and in working order.
My point exactly (see my post above). My car has 0 bar at 0 RPM.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-16-2003, 09:11 AM
My 88 will sometimes creep above the "9 oclock" position if I have the AC on and I'm creeping through slow traffic. I'd like to find a way to manually make the fan come on rather than wait for it to come on at a really high temp. It would be even better to have a thermostat that switches on at a lower temp. Apparently it's set pretty high on the factory oil cooler.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 06-16-2003, 02:22 PM
banjomike's Avatar
You should seach this site a bit better. There is an article describing how to wire up a manual fan switch, and there is discussion about replacing the porsche thermostat (~248F) with a similar BMW thermostat (~210F).
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 06-16-2003, 04:41 PM
