What is this?
Found this little guy sitting on the FD. Can somebody tell me where it belongs? Perhaps an illustration.
Thanks!
Old 09-17-2022, 12:24 PM
Plugs the idle adjustment hole between the FD and sensor plate boot. Use a flashlight in the crack to see the hole.
206 637 4071
Old 09-17-2022, 12:42 PM
John,
That is the dust plug for the AFM (air flow meter) fuel mixture screw. There is a hole located between the air funnel and fuel distributor. The idle adjustment screw is the big screw by the side of the throttle body.
Tony
Old 09-17-2022, 01:02 PM
proporsche's Avatar
well? this is just an original plug -some call it a gold mine..If you still have it, be happy about it...i have sold these troopers for big bucks..back in the days of ebaying
as John and Tony said...
also get yourself this c/o mix tool from Stahlwille company 3mm allen
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-17-2022, 01:29 PM
Thank you both. You both gave me the correct location and now I know where two adjustment are.
I will try to put it back.
Thank you!
Old 09-17-2022, 01:36 PM
