nkotselas's Avatar
Proper way to mount lines along passenger side
I heard some pretty bad rattling over the past few weeks but no driving issues. Finally took a look and pulled the rocker panels.
The oil lines towards the jack point look slightly flattened but I haven’t noticed any temp issues so hopefully that is fine. The third smaller line is just free Willy all the way to the front of the car. What is the proper way to mount this line in the front fender? I won’t be able to get the car up until next weekend so I have a limited view at the moment. What’s the proper way to tuck it in along the passenger side rocker panel?
Old 09-13-2022, 05:38 PM
nkotselas's Avatar
https://imgur.com/a/ZRXSbfk
Does the smaller line just clamp to the larger lines in the front fender?
Nick
'78 Turbo Look w/ euro 3.2
Old 09-13-2022, 05:40 PM
Not sure what that 3rd line is for. I have only ever run / seen 2 copper oil lines up the passenger side.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 09-13-2022, 06:42 PM
nkotselas's Avatar
I’m not positive myself but was almost too embarrassed to ask
Nick
Old 09-13-2022, 06:43 PM
nkotselas's Avatar
It seems like it leads to my smugglers box where there has always been a completely destroyed charcoal canister or something? Maybe I’ll just yoink it out. Not sure if that was a euro car thing, an import requirement, or what
Nick
Old 09-13-2022, 06:49 PM
That is the AC return (suction) line. At least it is on my 85. The AC line mounts inside the pan seam while the oil lines are on the outside under the rockers
85 Carrera Coupe
Old 09-13-2022, 07:06 PM
Sheet metal screws and clamps.
Old 09-14-2022, 06:30 AM
It almost looks like someone has replaced a section of the A/C hose with a hard line.
Old 09-14-2022, 07:15 AM
BoxsterGT's Avatar
Porsche Crest
Photos would help....
Len
Old 09-17-2022, 12:35 PM
Send a message via AIM to fintstone
..and the A/C evaporator and fan in the smuggler's box...likely with the deteriorated foam seal on top that you are seeing.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-17-2022, 06:24 PM
