-   -   Relay testing (http://forums.pelicanparts.com/porsche-911-technical-forum/112651-relay-testing.html)
clovis911 05-29-2003 01:19 PM
Relay testing
Can you test a relay for operation? I may need to replace my DME relay, would like to to test it first, also my wipers dont work could it be the relay? THX
jeff m 05-30-2003 12:27 AM
Placing 12v across the 85 and 86 pins will energise the coil
with the coil energised you should have continuity between pins 87 and 30.
Some relays also have a 87a pin whick is a break contact.
A test relay can be made by soldering a lamp/bulb across 85 and 86. and shorting out 30 and 87
This will quickly show whether there is 12 and a ground to op a relay and will also appear to the circuit as an operated relay for very fast fault finding.
Jeff
