Mike the mechanic's Avatar
993 engined SC, hunting idle can chip help?
Hey kids, I have read that it is quite normal for a 3.6 to have a hunting idle when using a lightweight flywheel, and a proper performance chip can cure the problem. Is this true and what chip is recommended?
The car exhibits hunting idle when fully warmed up. Checked for vacuum leaks or other possible problems and everything checks o.k.
thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-29-2003, 06:30 PM
marcesq's Avatar
I have read the same thing, and think that centex is one of the chips used by conversioners.
There are plenty on the board so maybe they will chime in.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 05-29-2003, 06:48 PM
Rick Lee's Avatar
Which year 3.6 do you have? After '95 I'm not so sure it's an easily chippable fix. Drop Steve Timmins a line at
www.instant-g.com. He does this stuff for breakfast and stocks everything you could ever need.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-29-2003, 06:52 PM
I forgot to mention this is a 1995 3.6, pre OBD-II.
Thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-29-2003, 06:59 PM
Go to http://www.rennsportsystems.com and I think you will find a lot of the info you are looking for. The 993's used the dual-mass flywheel to keep idle speed steady and to keep the revs from dropping to low and stalling when coming to a stop. The DM flywheel and the DME worked together to prevent this, but it is easier to chip a '95 than the '96. I just bought a '96 and I know that according to Steve Weiner at Rennsport if I ever switch to the LW flywheel I will have to buy a DME from a '97 because the '96 is not chippable. The '95 is the easiest to chip and according to the 993 board on Rennlist, Steve Weiner makes one of the most effective chips around. You might want to call him if you have other questions.
Old 05-29-2003, 09:33 PM
Bill Verburg's Avatar
Since the ? was about a 993 engined SC, the dual mass fly wheel has long since departed the scene. From my experience the idle should be rock steady even w/ a stock chip. Hunting at idle could be from one or a combination of issues Such as
  • Dirty Idle stabilizer
  • Vacuum leak(ok I know this was checked)
  • O2 sensor ist kaput
The chip can cure the issue related to dying on trailing throttle when coming to a stop.
The '95 has a nice easily replaced 55 pin chip
Bill Verburg
Old 05-30-2003, 04:02 PM
What Bill said. The chip used in the conversions are not used to prevent the idle from hunting. I would double check for vacuum leaks and put a gas analyzer on it. I would bet on the fuel mixture being too rich.
Old 05-30-2003, 04:08 PM
Bill, the reference was to a LIGHTWEIGHT flywheel. I believe the sympton Mike suggested do relate to the issue with the DME interaction. I am not the expert on 3.6 installations you are, but I do know the 95-98 3.6's do have this problem and it is related to the chip in the DME. Take it for what it's worth.
Old 05-30-2003, 04:09 PM
RETIRED
Joe Bob's Avatar
I have a cyntex chip clone available, BTW....most likely a vacuum leak.
2012 ML350 3.0 Turbo Diesel
Old 05-30-2003, 04:11 PM
Guys, thanks for all the replies. Your opinions/advice is higly regarded. Mikez, how much for the chip?
Paul, come to think of it, the car DOES seem to run a tad on the rich side. I know there are no adjustments to be made, all the tune-up related parts are new, no vacuum leaks, injectors have been cleaned, so this leads me to belive that the MAF may be going bad. He still wants to upgrade the chip for more power, so we'll see what happens after the we replace it.
What's a good way to check the MAF?
Thanks guys!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 05-30-2003, 08:39 PM
Banned
hmmm if it was OBD II there is an idle relearn prosses
but for 95 i am not sure
i did this on a GM once
disconnect battery to clear the memory
reconnect let car idle for 15 mins shut off
start again and let it idle for 15 more mins
all with out touching the gas pedal
i have no idea if this will help this car or not
but its free maybe worth a try
LATE
K
71` 911
Old 05-30-2003, 08:50 PM
The manual for my '96 state that after a battery is disconnected, start the car and let it idle for 10 minutes. When the battery is disconnected, the DME loses all codes stored and has to remap everything on startup and it takes 10 minutes to do so. It also says the idle may be too high or may shift up and down during that time.
Old 05-31-2003, 08:24 AM
