Red face Zenith Broken Enrichment Solenoid
While disassembling our Zenith 40 TIN carburetors, this part snapped off. I believe it is the enrichment solenoid. So now I've got this tube sticking out and no way to get the brass threaded portion out of the body.
Is that pipe something that can be sacrificed? Meaning can I cut it out so that I can try to extract the brass portion from the body and get a replacement for it? My guess is it is only retained by the brass, but that is only a guess.
I see the solenoid and a gasket in a Zenith manual. I'm not seeing that pipe though. So I don't know if it's even available to replace.
Old 09-18-2022, 11:49 AM
I will double check my spare set that already has the enrichment removed. I'm pretty sure it just gets plugged.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 09-18-2022, 12:17 PM
Just checked and it's plugged on my zeniths.
Old 09-18-2022, 05:56 PM
Thanks for checking. Does that mean that black tube is captured by the brass ring? I can drill it out and won't have damaged something permanently attached to the carb body?
Old 09-18-2022, 06:13 PM
proporsche's Avatar
i think i have one if you need it..have to look.
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-18-2022, 11:44 PM
proporsche's Avatar
i have found it..in my tool box where i have put it about 35 years ago;-)I believe back in 1987..just checked it and it works
Ivan
Old 09-19-2022, 01:58 AM
Question
Ivan
@proporsche Could you please share a photo of the end that inserts into the carburetor? I'm trying to confirm whether the black tube is part of the carb or the solenoid. Thanks.
Old 09-20-2022, 05:32 AM
proporsche's Avatar
most likely part of the solenoid...but you cannot see inside..
Old 09-20-2022, 05:52 AM
Cut the tube flush and seal the area with JB weld or something. You don't need that thing.
206 637 4071
Old 09-20-2022, 08:20 AM
I was able to find a photo of the cavity with it removed. Gave me the confidence to pull it out. The tube wasn't even captured. I was able to remove it by pulling, while the brass part was still screwed in. I was able to remove the brass with some finesse and a bolt extractor. All good now. Thanks for the info.
Old 09-20-2022, 08:49 AM
proporsche's Avatar
John..i just realized that is exactly what i did back in the 1980`s and it ended up in my tool box;-))))
Thanx for refreshing my brain
Ivan
Tags
carburetors , zenith , zenith 40 tin
