Turn signal won’t turn off after the turn
Ok, I’ve searched plenty about this, what I find is the high beam issues. My turn signals will only sometimes click off after straightening the steering wheel. Right side worse than left, but both are sporadic. Maybe a good contact cleaning? I can hear the click in the column only when they turn off. Dirty springs? Thanks
75 911s
Old 09-26-2022, 12:15 PM
Send a message via AIM to fintstone
Probably the cancel tab on your steering wheel is broken or worn down (or a possibly a mismatch if you have an aftermarket wheel). Search for turn signal cancel. or cancel ring.
A lot depends on year and model of your car in this forum. You should share that in your post of signature block if you ask for help.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-26-2022, 12:21 PM
Ok, I’ll dig in thank you.
75 911s
Old 09-26-2022, 12:35 PM
Uncertifiable!!!
Uwon's Avatar
Loose steering wheel hub will do it. After market steering wheel May do it. Extra think washers, a common fix for a wobbly steering wheel will certainly do it. Loose cancel switch will do it.
Patience.
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 09-27-2022, 03:17 AM
