Unhappy Bent Throttle Shaft
It appears to me we have a bent throttle shaft. Is it possible that I would have success just replacing this shaft with a new one? Or is this merely a symptom of a more serious issue that needs professional attention?
I started rebuilding our Zenith 40 TIN carburetors. I thought I was just cleaning and replacing gaskets. Perhaps some jets. Removing the enrichment feature. I've torn down one carb. I noticed that the throttle plates would not return to closed by force of the shaft return spring alone. Above half way there is a bit of resistance. Investigating that, I found two bent throttle plates and now it appears the throttle shaft is bent too.
Not sure where to go from here...
Old 10-10-2022, 08:48 AM
I believe Klassik automotive school replaces both the shaft and butterfly plate when doing Webers. This might be a case for that too unless the butterfly's are also fine. You can just buy new shafts and install them.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 10-10-2022, 09:08 AM
That would be great. I guess I'm trying to understand what could cause the throttle plates and shafts to get bent in the first place.
Old 10-10-2022, 10:05 AM
Flat Six
Flat Six's Avatar
Backfire, probably
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 10-10-2022, 12:16 PM
E Sully's Avatar
I wonder if trying to just replace them would work. Trying to remove bent shafts might damage the bores that it passes through, if they are not already damaged from the force that bent them.
Ed
1973.5 T
Old 10-10-2022, 03:08 PM
Good news if the bores are ovaled new bushings can be installed.
Old 10-10-2022, 03:33 PM
digitaldgp's Avatar
I had my Zeniths rebuilt by Dave Cheney, they are a work of art!!
He line bored the throttle shaft bushings and installed new Oversized shafts, couldn't be more happy with now. I also had him upgrade my carbs to Sport, 32mm venturies and etc.
https://www.dccarburetorrestoration.com/
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
1967 911 Sold but Greatly Missed!!
Old 10-10-2022, 04:06 PM
I’ve straightened shafts on DRLA Dellorto’s and Carter AFB’s and had great success.
Old 10-12-2022, 11:30 AM
I think that the shafts can be bent by unequal and over torquing the carbs to the manifolds.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-14-2022, 10:21 PM
Question
Originally Posted by digitaldgp View Post
Are the top gaskets in the right place? It seems they should be under the filter base.
Old 10-14-2022, 10:25 PM
Possibly, on the Zeniths I just sold the K&N base plates had a slot for the gasket on top between the stacks and the base. These don't look like that type and should probably go underneath.
There is also an argument for both top and bottom unless it could be proved that the stacks to the base plate are perfectly flush.
Old 10-15-2022, 06:24 AM
digitaldgp's Avatar
I had extra's so I installed them on top of and under the air filter plates.
1970 911T "Albert"
1986 944 Sold
1980 Euro 924 Sold
Old 10-15-2022, 09:08 AM
Perfectly acceptable especially since I have actually seen where flow through the syncro was off due to air being sucked in below the stack as the stack had been over tightened creating a gap. Tip: balance carbs with base plates and stacks removed in order to get correct readings at the top plate.
Old 10-15-2022, 11:51 AM
Tags
carburetors , zenith , zenith 40 tin
