-   -   turn signal dimmer switch issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1127950-turn-signal-dimmer-switch-issue.html)
durts123 10-11-2022 01:03 PM
So I just rushed through replacing the turn signal dimmer switch in my '81 911SC Targa. My wipers are in the off position but are going on and staying on unless I put downwards pressure on the wiper switch. Thoughts on what I did wrong or broke along the way ?
porschedude996 10-12-2022 08:18 AM
Since you’re able to turn the off at the stalk, I would say it is the switch. Other wise if the wipers are on all the time it would be in the motor “Internal Park Switch”. Check out the contacts on your wiper switch. They are exposed and operate the switch and see what’s going on.
