Gasoline Octane for 1977 911S
Looking the specifications for my 1977 911S, i found that the octane recommendation is 91 RON - I do not know the equivalent here in the USA
Old 10-20-2022, 04:45 PM
Full Send Society
87. Your 1977 911 will be totally happy with 87.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 10-20-2022, 07:04 PM
Bill Douglas's Avatar
Yes it's a low compression engine (8.5:1 if I remember correctly) so it doesn't need the higher octane fuel.
Old 10-20-2022, 10:42 PM
Functionista
manbridge 74's Avatar
Counterpoint: When it’s over 100F and engine is well loaded consider highest octane. Many 77 cars did not come with an oil cooler leading to quite high temps..
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 10-20-2022, 10:46 PM
So does this mean a typical 2.4 would likely be ok with 87 octane rather that
running the higher more expensive octane fuel. Would it be the same for the
“T” or an “S” engine.
Sorry not meaning to hijack the thread just find it interesting.
Mike
Old 10-21-2022, 04:41 AM
Bill Verburg's Avatar
Just a data point but my '76 C3 w/ the same 8.5 cr though a 3.0 instead of a 2,7, ran fine on leaded regular but didn't when leaded disappeared, In the post leaded era I always had to use high test
Bill Verburg
Old 10-21-2022, 05:32 AM
kent olsen's Avatar
With the high price of fuel I've been running my 72T with a 9.5:1 twin plug 3.0L on the mid grade. I feel if you don't push it the engine will be fine. Just my opinion.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 10-21-2022, 09:33 AM
91 RON is 87 Octane. My 77 2.7L runs fine with 87 octane. Higher octane gas will have better detergents but aftermarket additives added to every other tank of 87 will compensate for the +$1 more for 91 octane at the pump, plus additive treatment keeps the carbon in check and the gas fresh when in extended storage.
Old 10-21-2022, 10:02 AM
