-   -   82SC won't run after starting (http://forums.pelicanparts.com/porsche-911-technical-forum/1128613-82sc-wont-run-after-starting.html)
joe912/62 10-22-2022 11:24 AM
Just did a back date of the heating system of my 82SC, removed all the original hoses and engine heater blower. Had to undo the distributor cap and removed the spark plug wires 1,2,3 on the driver side to facilitate the installation of the heater duct. Installed everything and car fired up drove it for 10 minutes and after it would turn off after stopping at traffic lights or stop sign. Engine restarts but shuts down immediately. Managed to get it home but it still starts and then shuts down.
Any ideas were to begin?Any help would be appreciated.
Demetri 10-22-2022 11:34 AM
Double check distributor and alll wires on cap are correctly fitted. The last thing you did is typically culprit
joe912/62 10-22-2022 12:42 PM
After sitting for about an hour and starting the car, it seems to idle now but I haven't
taken out to test drive it to see if the issue comes back.
Any ideas?
icarp 10-23-2022 06:10 AM
Fuel pump, or fuel filter ?
Relay?
Ian
joe912/62 10-23-2022 08:51 AM
Just started it and pulled it out of the garage and let it run for 5 min, once I put it into gear and gave it throttle it turned off. The car was running well before I did the modifications. The only thing I removed was the spark plug wires the coil and the distributor cap everything else remains the same.
kltarga72 10-23-2022 05:37 PM
When engine is idling for those five minutes is it idling smoothly with no miss or back fire? What happens when you rev the engine, does it sound correct?
As Dimitri pointed out double check plug wire location, loose or incorrectly seated distributor cap. Also visually check both ends of the coil wire
Schulisco 10-24-2022 01:53 AM
Could be accidential. Must not be related to the last repair.
Check if either the spark is missing or weak - there are some ignition spark test plugs available. Be extremely careful on the super high voltages of the CDI!
Probably a dying ignition coil - for idle the power may be sufficient enough, but when trying to drive the spark is not strong enough and it's shutting down. Might also be a temerature problem of either the coil or the CDI ignition box. Do you have ice spray? Start the engine. If it stalls, cool down either the coil or the CDI box with the spray and try to restart. If it restarts - voilà.
You can check the ignition coil by measuring the resistance:
https://forums.pelicanparts.com/porsche-911-technical-forum/299530-bad-coil.html
Make sure that never ever a spark plug wire gets loose when the engine runs - this can destroy the CDI box (ignition spark backfires into the box and toasts it!).
Thomas
Bobboloo 10-24-2022 06:18 PM
Could be your CDI. It's not uncommon for transistors to fail when they get hot.
David Inc. 10-25-2022 05:42 AM
Did you do anything with the vacuum lines in this work? Maybe pop one loose while doing the work and put it back on the wrong connection? Accidentally adjust ignition timing while working at the distributor?
Kind of a funny one, but maybe you bent the microswitch at the throttle--mine was bent at one time and would constantly shut off on me because it would think it was on throttle while idling.
Obvious thing, make sure those ignition wires are fully seated on the plugs.
joe912/62 10-25-2022 06:39 AM
I measured the resistance and got these numbers, my ohm reader isn't very accurate so
Primary .5
Second .690
don't know if I need to move the decimal point.
Schulisco 10-25-2022 07:46 AM
Primary .5
Second .690
Don't get me wrong - but these numbers are worthless without any scale. If you do not know how to handle and read the values make a picture and post here.
From my very first impression - I would say there's something wrong with the coil, refer to these numbers as previously mentioned:
https://forums.pelicanparts.com/uplo...1155967959.jpg
Thomas
David Inc. 10-25-2022 08:13 AM
If he's looking at a 2k scale then that .690 would be 690ohms which is in range for that coil. I think it's 600-900 ohms. Don't know why but mine is in that same range (just had a thread about it too).
Kind of light on good information here but I'm banking on it being related to something getting dislodged during the backdate or one of the plug wires (cap wire too) not being fully seated.
joe912/62 10-25-2022 08:39 AM
So you think the coil is still good?
joe912/62 10-25-2022 09:08 AM
So set to 20K I get
.00 primary
.69 secondary
Bobboloo 10-25-2022 09:18 AM
Your coil is probably okay. .5 ohm primary is good and 6.9k secondary is good.
David Inc. 10-25-2022 09:25 AM
Probably, unless you zapped it with a bad connection putting it back together. First thing before you start chasing broken parts is to make sure that you have everything back together nice and tight. If I remember my OEM plug wires right they could sometimes feel like they were on but actually took a lot more force to fully seat.
I'd say verify that you plugged everything back in properly (including vacuum lines you might have disturbed) and only then start worrying about broken components.
Bobboloo 10-25-2022 09:29 AM
I've never seen a coil malfunction in this particular fashion. Usually when they fail they don't start working again when they cool down.
I'm still suspect of the CDI because that's a normal failure mode for them. They work fine when cool and then they quit when they get hot and need to cool down again.
Make sure the CDI has a good ground. They hate it when they don't have a good ground. It can fry the electronics if they lose ground while in use.
kltarga72 10-25-2022 05:21 PM
joe912/62
" The only thing I removed was the spark plug wires the coil and the distributor cap everything else remains the same."
Joe, this statement you made is where you need to concentrate your troubleshooting efforts.
If you pulled 1,2 and 3 spark plug wires off from the distributor cap then make sure you reinstalled in correct firing order.
A static ohms check on the coil is only the first check made when testing a coil, they will break down internally when engine is running. Swapping with a known good coil is the best test.
joe912/62 10-26-2022 03:55 AM
I pulled the wires from the spark plugs not the distributor.
I numbered them when I pulled them off.
But I did notice last week before doing the changes that when I started the car there was a high pitched noise, I turned it off and restarted and the sound went away. Could that have something to do with it?
Bobboloo 10-26-2022 06:32 AM
The high pitched noise is from the CDI. If you hear it when the ignition is on then that's a good thing. If you don't then it's not working.
Not hearing it while the engine is running is just from the masking effect of the engine running.
Here's an easy test for you:
1. Turn the ignition to "on" with the engine cold but don't start it. Do you hear the high pitched whine? If so good.
2. Start the car and let it run until fully warm. Shut down and then try to restart. If the car is in failure mode and won't restart then again turn the ignition to "on". Do you hear the high pitched whine? If not then the CDI is in failure mode. Diagnosis bad CDI.
joe912/62 10-26-2022 07:18 AM
No high pitched whine, never remember having hearing one before.
Car started right up then I turned it off, started it again and did hear a short whine for a split second and it went away, turned it off again started right up, short whine and went quickly away and run smoothly. I haven’t let the car warm up yet
Bobboloo 10-26-2022 08:15 AM
We need to establish the testing method. You should be listening for the whine with the ignition on but without the engine running.
1. Engine not running-cold-inition on. Whine?
2. Engine not running-full warm-ignition on. Whine?
Schulisco 10-26-2022 08:43 AM
Make a video with good sound quality and post it here. Everything else is reading coffee ground....
joe912/62 10-26-2022 09:00 AM
No whine on cold start up or after warm up, basically no sound.
David Inc. 10-26-2022 09:50 AM
If it's running you're getting the whine but you might need to stick your head in the engine bay to hear it well. Open the engine bay, turn the ignition to "on", not "start", (engine should not be running) then get out of the car and listen in the engine bay. The CDI should be whining.
Bobboloo 10-26-2022 10:16 AM
Is the CDI Bosch, Permatune or MSD?
Funracer 10-26-2022 11:01 AM
Owned my car over 2 years now and have never heard the whine. Wife says it whines every time. My hearing is shot in that frequency range. So if it quit whining I wouldn’t know it. Just saying, sometimes its not the car thats not working.
Bobboloo 10-26-2022 11:30 AM
Hear! Hear! or should I say No Hear! No Hear!
I'm right there with you.
joe912/62 10-26-2022 12:06 PM
It's a Permatune
Bobboloo 10-26-2022 06:16 PM
Nevermind. Permatune don't whine.
Do you have access to another CDI that you can swap it out with temporarily?
joe912/62 10-27-2022 11:57 AM
I replaced the fuel pump just to rule that out, no change still does the same thing.
Dave Kost 10-27-2022 02:26 PM
Check if the frequency valve is working. You could have knocked off the electrical plug on the firewall.
joe912/62 10-27-2022 03:07 PM
Where is that located
Dripola 10-28-2022 08:18 AM
Did you check your vacuum line connections? I had the same symptoms when I removed my WUR, turns out I didn’t reconnect my vacuum line properly. Also, make sure your wiring harness plug connector isn’t loose.
joe912/62 10-28-2022 09:39 AM
The one's to the distributor?
Schulisco 10-28-2022 10:22 AM
Refer to https://jimsbasementworkshop.com/CIS/pages/descr_lambda.html
The frequency valve is here named as "timing valve (#11)". This name might confuse a bit. It realizes the the lambda control on managing the mixture for the fuel distributor. It's controlled by the ECU under the passenger seat and is located right behind the air filter box close to the throttle valve. It must be vibrating when engine is cranked and fuel pump is running. If it's not working engine start is hard but not impossible, but the engine won't run on her own without pushing the throttle to keep the engine running.
Get familiar with the lambda CIS as much as you can to get the engine running again. From far away it's pretty hard to find the culprit because in the end - everything on a CIS could be the reason.
I heavily also recommend Curts YT Channel from Klassikats.com:
https://www.youtube.com/playlist?list=PLkWFofpgz2OgF9FdliKnlzuY0pygqRkMj
Although those videos are primarily intended for the 2,7 CIS engines, the priniciples are pretty the same on a 3,0 SC.
Thomas
Funracer 10-28-2022 06:06 PM
Might do a quick WUR pressures check. My 83SC was doing the “start but won’t run” thing for a few weeks. Finally figured out the WUR cold pressure was out of spec high and so leaning the mixture too soon. So the car would start on the CSV fuel shot and run for a second or two then shut off. As soon as I lowered the CCP to spec for the ambient temperature it starts instantly and runs perfectly again.
joe912/62 10-29-2022 08:29 AM
I start the car and let it idle for at least 5 min. and it runs at around 900 rpm without issue. When I give it throttle to rev the rpm's higher the rpm drops to around 600 and the car seems to want to
stall, the rpm seems to go up to 900 and then drop again. If I turn off the car and try to start it again it will not start or stay running without giving it throttle and then shuts off. If I let it sit for 5 min the same thing happens.
Rsnellie 10-29-2022 09:58 AM
I’m with funracer on this one. Maybe you disconnected the WUR or bumped the connection. It is right there where you were working. A pressure test will tell you almost everything you need to know. I had a similar problem and it ended up being the WUR even tho I just replaced the fuel filter. I was 5 psi off and that was the difference between a running car and a stalling car.
joe912/62 10-29-2022 11:39 AM
Just tried it again an hour ago, started doing the same thing. I went through the same process a few times and then it began running normally. I increased the fuel mixture a bit too increase the RPM's . I decided to take it around my neighborhood to see if it would stall at stop signs and it didn't. I turned it off and waited around 5 min and fired it up again and took it for another drive.
I then left it for an hour and it fired up again and it seems to be running normally again. There is 2 vacuum lines to the distributor, one orange and one black. I noticed when I reconnected the black one yesterday that the end of the hose had a small piece of something that looked like metal. Could that have been the problem?
