-   -   Replacing lug nuts (http://forums.pelicanparts.com/porsche-911-technical-forum/1128674-replacing-lug-nuts.html)
josephvman 10-23-2022 02:30 PM
Replacing lug nuts
I'm getting ready to replacing my beat up lugs nuts on my 16" Fuchs wheels with new Porsche OEM alloy lug nuts. Is there any issue doing this on the ground, replacing one-by-one and tightening to maybe 70ft/lbs, and then when they're all done, torquing them in the correct pattern to the correct 96ft/lbs? I've already got a soft socket.
winders 10-23-2022 04:00 PM
If you are worried about it, replace them in star pattern order torquing each one fully.
DWeg1998 10-23-2022 07:15 PM
I think you’ll be fine here and shouldn’t worry. Retorque the wheels after a couple days if it brings you peace of mind.
mike sampsel 10-24-2022 09:16 AM
Should be fine to torque to the 96, the other four already have the wheel secure.
Star pattern is best when replacing all the nuts on the wheel, you are doing one at a time so it would seem to be not needed, but is still best most of the time to do a star pattern tighten sequence.
techweenie 10-24-2022 10:28 PM
I'm not a fan of the soft sockets.
I prefer a standard 19mm / 3/4" socket. I use a piece of a plastic garbage bag -- or Ziplock -- putting it over the lug nut and sliding the socket over it. I've never scarred a fresh lug nut, while I've had the soft sockets leave marks.
Correct tightening pattern is tracing a star, as winders said.
shoooo32 10-25-2022 05:15 AM
Since we're on the subject of lug nuts, what's the go-to compound these days for anti-seize?
Brush on? Paste? Dry graphite spray? Raw doggin' it dry?
winders 10-25-2022 07:22 AM
This is what recommends for the aluminum lug nuts:
https://www.pelicanparts.com/More_Info/00004330508.htm?pn=000-043-305-08-OEM&gclid=Cj0KCQjwkt6aBhDKARIsAAyeLJ0z9Y_H63cPXQiL 2ZqjAJKlHo_hhstD4N5nvfDNS9u-ZGI9pz9Yu14aAtSdEALw_wcB
josephvman 10-25-2022 09:12 AM
Just to confirm, the torque is 130 N-m, and using anti-seize, correct? Does it make a difference if the anti-seize is copper or silver based?
winders 10-25-2022 10:58 AM
The torque is 130Nm. But, with anti-seize, you should decrease torque by 30% as the that 130 Nm is a dry number. This is where it gets weird. Porsche claims that that Optimoly TA does not affect torque. That has not been my experience.
Personally, I would use 91 Nm or 67 ft-lbs with an anti-seize.
mike sampsel 10-26-2022 03:50 AM
Anti to anti-seize on lugs/plugs comment
My wheels come off often enough to not worry about the aluminum and steel stud incompatibility. I’ve used anti-seize on exhaust bolts and oil cooler lines, but no where else.
There are experts on both camps of anti-seize on plugs, as an example Ed Mayo and John Walker have different positions. For an engine getting plugs which might sit with them for many years, anti-seize might make more sense.
Center lock nuts on GT3, GTS, Turbo seem to spec the lube recommended. The torque spec is 444’ lbs there. And for tracked cars I saw a recommendation of changing the nut every 6k miles, wow.
I’ve used anti-seize long ago on lugs, and never again for me.
Ditto on plugs, long ago. Not happy with either results. YRMV though.
sean m 10-27-2022 11:15 AM
Damn.....based on this post ,thought I'd look at replacing mine as well.
After seeing the cost........I think I'll look at painting my lugs as they're really an afterthought at this point.
safe 10-28-2022 04:24 AM
Why would there be an issue with that? Replace one by one in any order you want and torque to the full torque in one go.
Marine Blue 10-28-2022 05:25 AM
I recently replaced mine and something I’ve noticed is that they seem to need frequent torquing initially, at least in front. So make sure to check them again after you put some miles on them.
dg567 10-28-2022 05:36 AM
I can help you out - the cost isn't so bad!
https://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1114969-black-aluminum-lug-nuts.html
sean m 10-28-2022 06:53 AM
Originally Posted by dg567 (Post 11832760)
DG....thanks, great option.
Superman 10-28-2022 08:54 AM
For peace of mind, I use these. Steel. The threads go all the way through the nut.
https://www.pelicanparts.com/More_Info/N0201121.htm?pn=N-020-112-1-M36
josephvman 10-28-2022 03:42 PM
I've got center lock nuts on my GT3, and the procedure to change those wheels is exhausting, with things you'd probably not consider, and I just wanted to make sure I wasn't missing anything on my old car.
daepp 01-29-2024 10:51 AM
Sorry for the hijack - just curious if the OEM lug nuts are ever replaced pro-actively?
AFAIK mine are fine, but my car is almost entirely stock and was manufactured 52+ years ago.
I had a few in my hands the other day and I was reminded how little mass they have - do they wear out?
Full disclosure - I have never had one get loose on me, so there's that...
winglesss 01-29-2024 11:07 AM
Those are designed for the steel spare tire / wheel and are specified in multiple Porsche technical bulletins as a usage requirement instead of the standard lug nuts in that application.
I picked up a set of five for my on board tool set for usage if-required.
theiceman 01-29-2024 11:12 AM
anti seize on the base of the nut ( the "ball" area ) where it contacts wheel only..
putting anti seize on the threads will put massive clamping force on those wheels .
winglesss 01-29-2024 11:28 AM
Actually multiple Porsche Technical Bulletins state: "Before installing: lubricate threads and shoulders of aluminum nuts with Optimoly TA, Part No 000 043 020 00. (Optimoly TA does not affect tightening torque.) Torque nuts to 130Nm (96 ft. lbs.)"
My experience w/ both the Optimoly TA and w/ Anti Seize Lubricant appear to have identical characteristics to me. My 911 will continue to have the specified Optimoly TA applied per the Technical Bulletins and the Anti Seize will be used for other applications.
Ian Comerford 01-29-2024 11:52 AM
Have to agree with the above. A significant amount of clamping force is lost due to friction in the threads, so adding something to reduce that friction increases the chances of the wheel staying where it is
David Inc. 01-30-2024 06:37 AM
I feel like you guys are overthinking this way too much. Not too much **** on the stud threads? Check. Torque to 96 lbft, done. Accidentally over torque to 110? Whatever. I've never used anti-seize on my studs in ten years and no issues reported. I do take my wheels off at least once a year, though, but I'd imagine that's fairly typical for Porsche owners who drive their cars.
HarryD 01-30-2024 12:20 PM
Just saying.
http://forums.pelicanparts.com/uploa...1706646034.jpg
MBAtarga 01-30-2024 02:06 PM
Guys - this is a resurrected thread - the last new post is #18 which is a new question.
Stop reading the thread from the start and skipping to posting a response.
David - to answer your question, I think most replace the lug nuts "periodically" because of their worn appearance - not because of any failure. Even being careful - the soft sockets can still impart some worn edges - and over time the color does fade. I've owned my Targa for 22 years now - and have replaced them all twice.
David Inc. 01-31-2024 04:18 AM
Oh no I fell for thread necromancy? The shame of it all!
josephvman 01-31-2024 04:15 PM
Strange seeing an old thread of mine coming back!
FYI to those considering replacing your lug nuts for strictly cosmetic reasons; the new OEM lug nuts I ordered came shipped loose in a bag, and ultimately didn't arrive looking a whole lot better than the ones that had been on my car for almost 40 years! I called the vendor, who said that's how they get them.
dg567 01-31-2024 06:09 PM
https://www.tiporscheproducts.com/product-page/aluminum-closed-end-lug-nuts
Mine ship like this in a box
https://static.wixstatic.com/media/f...3c44e6~mv2.jpg
winglesss 01-31-2024 06:31 PM
Originally Posted by dg567 (Post 12184373)
I'm a BIG OEM parts guy, but those parts look good to me and I've just ordered a set.
dg567 01-31-2024 07:14 PM
Paul, thanks! The finish on these is far superior to what OEM is offering today.
AG81 02-01-2024 01:08 PM
Boxed nuts are the best.
