Trans not sliding into engine all the way
I have done this procedure many times but never been stumped like this..
Engine is an 86 3.2, formerly installed in a 76 with its original trans. The 76 trans has grown notchy and difficult to shift. So, I have a rebuilt 79 trans that I am installing. It slides into the engine ok, but stops short about a half inch. The spline lineup tool slides in and out fine. The pilot bearing shaft, spline, and guide tube are all the same diameter. The shift fork is in the pilot bearing groove. I have notched the housing for the sensors. What am I missing, or what have I done wrong? Thanks in advance for your help>
Old 10-24-2022, 04:39 PM
Put two bolts in each stub axel , set one side so it can't rotate, using a screwdriver.
Then rotate the other with another screwdriver and the input shaft will spin, allowing the splines to rotate to alignment .
While doing this push the trans further to mate with the engine
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 10-24-2022, 04:45 PM
have you tried turning the engine over a little? This has happened to me more than once and a partial turnover using a ratchet on the crank pulley or fan bolt enabled it to slide all the way in.
Old 10-24-2022, 04:46 PM
Sometimes an edge of the engine sheet metal interferes been there a few times.
206 637 4071
Old 10-24-2022, 04:57 PM
More detail-engine is on a lift cart, trans is on a trans jack with a tilting table.
Old 10-24-2022, 05:08 PM
Warren Hall Student
Bobboloo's Avatar
Have you removed the clutch release arm from the release fork shaft? It can hit the heat exchanger if it's not removed.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 10-24-2022, 07:10 PM
Checked the pilot bearing to make sure there's not some FOD in there?
Old 10-24-2022, 08:39 PM
Clutch fork centered in the throw out bearing?
Old 10-24-2022, 08:43 PM
Half inch sounds like a pilot bearing thing--everything else would be lined up by that point.
1982 911SC
Old 10-25-2022, 06:05 AM
Pictures please
Old 10-25-2022, 08:00 AM
Diss Member
Quicksilver's Avatar
^^ That's my first thought too.
If the trans is in gear you can rotate it to see in the spines are aligned. (But at 1/2' they should be engaged.) If it wasn't a Porsche I'd think of an alignment pin.
Any chance that something was left on a mounting stud?
Only last thing I could think of is moving the release fork to be sure it moves freely to show it isn't pressing hard against something.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-25-2022, 08:18 AM
MichaelSJackson's Avatar
The starter gear not retracted and banging into the ring gear?
Old 10-25-2022, 09:30 AM
Well duh!!! Now I will have to sit in the front row and pay attention again!
I removed the clutch pressure plate and flywheel in stages, and kept test fitting at each stage-no joy. Even down to a bare crankshaft, it still wouldn't go in. So then I noticed the other sensor at the top of the engine case, where I had overlooked it and not provided a cut out in the bell housing. So-a couple of minutes with the grinder and good to go. At least there was some benefit from all that trouble-I replaced a leaking rear main seal.
Thanks for all the answers.
Old 10-25-2022, 03:01 PM
Warren Hall Student
Bobboloo's Avatar
Well you got it done. Good for you!
For future refer in case any else has this problem I thought I would mention that the sensor at the top is just a test sensor that no one ever uses. It goes to the little rubber plug under the idle control valve. It can be removed and discarded.
Bobby
Old 10-25-2022, 08:31 PM
