Ignitor Electronic Ignition
Anybody have any experiance with the Pertronox Ignitor® Electronic Ignition sysyem. The claims sound pretty good for a $65.00 part.
1974 911 2.7L coupe with sunroof |
Friend of Warren
They have been around for years. I think they have an ignition set up for every car in existence that ran on points. I know lots of British Car guys that run the Pertronix system with no complaints. Some of the guys on this board do also. I think they exaggerate their claims, but most manufacturer's do. I probably would not buy their coil as I think the Bosch Blue Coil is superior. Personally I have never had a problem with a points ignition and continue to run points on my '58 Sprite, '72 MGB and, when I owned it, '72 911.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Double Trouble
I have the Crane system in my 70 S car and I love it. SET IT AND FORGET IT!
I used to be addicted to the hokey pokey..........but I turned myself around.. 75 914 1.8 2010 Cayenne base |
we put the pertronix in about 6 weeks ago. car runs great. we have an msd 6al and the install was easy(after removing the distributor)
1975 911S Targa Silver Anniversary Edition |
Hello Silver,
today i install a msd 6al and pertronix with new coil and wires like you in 1970 ... i have one question about wire , where do you connect the black/purple for the tack ? i have no tack presently... Thank You Ray
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
ray
i posted before on this but try again. after you connect the msd install the pertronix. the red wire on the pertronix goes to the #2 fuse block in the engine compartment fuse holder. i used a heat shrinkable connector to extend the wire for this. the black wire on the pertonix goes to the wires that are presently connected to the points. do not connect to the coil...do not connect to the coil. i think that there are presently 3 wires that connect to the points. use a heat shrink connector to splice to the black wire on the pertonix to these 3 wires. it is very simple. my msd was installed by the previous owner so i cannot help with that. just remember that the pertonix needs power to run hence the red wire and it sends a trigger signal to the msd and the tach via the black wire. the pertronix does not connect to the coil directly.
Thank You for your help ... i do exatly the same like i reed in the search
and my engine is running verry good but it is only the tack i don't want to make a mistake and broke my tack. i want to be sure before connecting at the bad place, the instruction in english is not clear for me a french canadian ! Thank You Again RAy
ray
the wire that connects to the black wire on the pertronix also connects directly to the tach in my car a 75s gary
MSD
Thanks gary,
i try it saterday and my tack received signal but stay around 3000 rpm i will try a tack adapter like this diagram... Ray
