1986 911 Carrera headlight switch
Hey guy's Have an issue with my 86' headlight switch wiring. I've checked out the previous posts and pic's. The Bently manual does have a lot to be desired. Thanks to Targa 911 for the breakdown of the wire coding. Does anyone have a pic of their switch handy? Many thanks
Old 12-09-2017, 03:05 PM
Formerly known as Syzygy
Canada Kev's Avatar
I had an issue with my switch wiring after I bought my 1987 car. I thought it was a bad switch, which it was, but a PO had changed the wiring to get the headlights to work, but they didn't work exactly as they were supposed to. Sorry, no pic of the attached wires on the switch.
Anyway, when I got my new switch I had to figure out the wiring to see what the cock-up was. This thread covers that, but perhaps more importantly, I did up a matrix of what the terminals on the switch are supposed to do. If you are able to do some experimentation, this might help out.
Headlights not working properly?
Kevin
Old 12-09-2017, 04:34 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Headlight switch.
Here you go-All you have to do is ask.
This is from our '86.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-09-2017, 06:53 PM
sugarwood's Avatar
This are my notes from my '86
Originally Posted by sugarwood View Post
5a) Next, it's time to remove the wires from the old stalk, and connect the new stalk.
There are 3 wire harnesses that feed into the headlight switch.
I wrote down all the connections, in case someone ever mixes something up.
Below, each wire color is listed alongside the headlight switch terminal number it plugs into.
This is from a '86 coupe
Turn signal stalk harness
White/black -> 56 (White is the main wire color, black is the stripe color)
Grey/black -> 58L (inside)
Grey/red -> 58R (inside)
Red/white -> 75
Plug Prong harness
Grey/black -> 58L (outside)
Grey/red -> 58R (outside)
Grey solid -> 58 (between 56 & 30)
Grey/white -> N
White/green -> 57
Black/blue -> 58a
Electrical tape wrapped harness
Red/white -> 75
Red solid -> 30
Blue/black & Black/blue -> 58a
1986 Bosch Icon Wipers coupe.
Old 12-09-2017, 07:07 PM
Thanks for the help guy's. Found the problem, an oversight on my part. the diagrams were very helpful
Tim
Old 12-20-2017, 02:04 PM
TipToe's Avatar
I just used this thread to replace my headlight switch in my 1986 Targa!! thank you so much for posting, this really helped!
1976 Citroën 2cv
1986 Porsche 911 Targa
2012 Audi A7
2018 VW Atlas
Old 10-29-2022, 03:39 PM
