-   -   Dash Clock Replacement Idea (Go GPS / Digital) (http://forums.pelicanparts.com/porsche-911-technical-forum/1128992-dash-clock-replacement-idea-go-gps-digital.html)
cliyde 10-28-2022 09:37 AM
After years loathing over the stock 911 clock, I finally decided to do something about it and researched this awesome little multigauge for ALL you tech nerds. Check out the X95 from Autool. It is loaded with an array of features and data display points - including, YES - A clock. The best part about it, the clock is GPS enabled and updates automatically every time it turns on!
At a glance, this multigauge includes:
MPH
Altitude
Voltage
Time Driven
Distance Driven
CLOCK
Pitch and Roll degrees (not very useful for a 911) :D
I decided to hard wire the X95 to a spare/fused instrument gauge connection. This gives me the proper batt. voltage as opposed to the supplied cigarette lighter connection that only runs 5v. (So, Key on / X95 on. Key off / X95 Off).
As for fitment, luckily I had a spare clock housing and used it to fit the X95 in place. It did require shaving the plastic housing bevels to fit inside snugly. Once installed, the GPS reception degraded slightly, but still worked. The the clock/date info loaded fairly quickly, but location / speed data takes a few mins. I'm going to see if I can rig up an external antenna and will post what I find.
In all, wish I had a 3D printer to make a period correct looking gauge insert, but if I'm honest, this doesn't look half bad as it is!
Let me know what you guys think!
https://i.postimg.cc/fbD4P5wP/IMG-2206.jpg
https://i.postimg.cc/MHcgBFDn/IMG-2208.jpg
https://i.postimg.cc/C5WXssPm/IMG-2213.jpg
almostordinary 10-28-2022 09:52 AM
Kinda cool!
Was just thinking about options for this spot... my clock is toast as well, and something a bit more useful would be ideal. Period correct bezel would take this all the way home. Nice job
dg567 10-28-2022 10:42 AM
Pretty trick! Talk to John Bell, I'm sure he has some ideas on how you can mount that into a clock housing.
OldSpool87 10-28-2022 10:52 AM
You could use a clock delete plug from our host and cut a concentric hole the size of the multi gage. Warning- the plug is ridiculously priced.
cliyde 10-28-2022 11:00 AM
Thanks! Had not consider that option, but may try it since GPS signal works through plastic, rather than metal.
Cheers!
AlKidd 10-28-2022 12:00 PM
Clocks right 2x per day. Why change it? Should be looking at the road anyway. :-)
stevej37 10-28-2022 01:57 PM
Just get the original one fixed....
http://forums.pelicanparts.com/off-topic-discussions/1128504-clock-work.html
seafeye 10-28-2022 02:54 PM
Do they have one with a turbo boost gauge as well?
cliyde 10-28-2022 03:52 PM
It's not broken, I just don't like the boring, analog stock clock. :D
Originally Posted by stevej37 (Post 11833339)
cliyde 10-28-2022 03:53 PM
I don't believe so. I used the VDO boost gauge in my '84 turbo in the stock clock location with good success tho.
rokemester 10-28-2022 04:40 PM
Pretty darn cool IMO
Uwon 10-29-2022 05:20 AM
Yes, pretty cool. Thanks for posting.
Johan
Racerbvd 10-29-2022 08:21 AM
Very cool.
phelix 10-29-2022 11:24 AM
Pretty sure there a 3D print file of thingiverse for a 911 clock delete “plug”; you might be able to modify that design?
cliyde 10-25-2023 04:36 AM
https://i.imgur.com/IVKvdBw.jpg
https://i.imgur.com/xDu93XB.jpg
https://i.imgur.com/8vC4dFN.jpg
buster73 10-25-2023 07:04 AM
IMO the most valuable option: extra large oil pressure warning light (aka idiot light) - especially helpful when busy on the track !
http://forums.pelicanparts.com/uploa...1698242648.jpg
Funracer 10-25-2023 07:59 AM
This. JB does great work.
GothingNC 10-25-2023 09:01 AM
That looks cool !
I may look into it if my clock goes kaput.
