Placement of Oil Cooler Supply/Return Pipe Support Bracket
May be a repost. I swear I submitted this earlier today. Anyway, here goes:
I have an '87 Porsche 911 and I sent it in for service recently. When it was returned, I found this brace and I can't figure out where it goes. Porsche Engine Oil Cooler Supply/Return Pipe Support Bracket - 91120730300 https://www.pelicanparts.com/More_Info/91120730300.htm?pn=911-207-303-00-M260 Does anyone know where it goes? The oil cooler is in the passenger side front fender. Thanks for any help. -Frogsickle Edit: Changed the year. Last edited by frogsickle; 10-31-2022 at 01:10 PM.. |
lake wales fla
Are you sure it is not a 79 ? 97 did not use that style of bracket. Try looking in the right rear fender well behind the tire, there should be a stud in the body that that bracket attaches to if it is not broken off.
Richard |
D'oh. I mean't '87.
Thanks for the direction. Will go poke around right now and report back. |
Fastens the long chassis oil lines to the chassis.
If you give your word: keep it. |
Under the passenger side rocker panel cover. There are 3 of them.
