Cam timing question
Hello all
![]() I am running this cam grind in my 3.2 short stroke and was wondering if it is beneficial to alter the timing, either retarding or advancing ? WEBCAM Grind: 120/104 Valve Lash (Inch): .004" Valve Lash (mm): 0.1mm Valve Lift (Inch): Intake 0.476 Exhaust 0.449 Valve Lift (mm): Intake 12.09 Exhaust 11.43 Advertised Duration: Intake 284° Exhaust 264° Duration @ 0.050" Intake 270° Exhaust 248° Lobe Center: 100° SET @ 5.2 MM WITH .10 MM LASH Cheers
I think web pretty much hits the nail on the head
it's not leaking....it's just marking it's territory |
It's a 914 ...
It's typical to time to cams according to the grinder's spec, unless you're trying to achieve a specific purpose like more top end, more mid-range, etc. This looks like a nice lumpy performance grind. Hopefully you're running carbs or ITBs.
I use specs as recommended unless I don’t like the valve to piston clearance, in that case I will adjust cam timing to suit.
Boy, I would heartily second (or third or fourth) what these guys said. The folks grinding these cams know what they are doing. Unless you have specific, hard data from a dyno with these cams in your motor (not one "just like it") with both the altered and recommended timing, you're just flying blind anyway.
I think this notion had its genesis with the SC motor, where some guys started to tout altered timing to increase torque. Can't remember if it was advancing or retarding the timing. At any rate, I think on the dyno the "area under the curve" was largely unaltered, just moved around a bit. No real advantage, just a difference in "feel". I see these cam timing questions as kind of a lingering "hangover" from those days. Best to stick with the grinder's recommendation.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
^^^^ Well said Jeff.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
