1979 911 SC
How to remove this stuff under my bumperettes?
Happy Saturday all, Trying to replace the original beat up US spec bumperettes on my 79' SC and I can find anything in my shop that will remove the old crud beneath. Feels like some sort of cosmoline type substance. A little disappointed at the condition of the paint underneath but too late to turn back now. If I can get this hard plastic feeling coating off it will go a long way to making the swap worth while. Any help would be appreciated!
Old 11-05-2022, 01:33 PM
I’m wondering if it’s just build up of wax or clear coat from any previous respray(s). What I see i don’t think it’s cosomline as there’s no need for it on/under painted aluminum bumperettes. I’d try warming the substance a bit to eliminate the cosmoline theory, which mineral spirits, wd40 would get it off with some work. If it wax or wash residue (white-ish is what I see in pic) it can probably be worked off with some griots correcting polish.
If it’s overspray, the polish will remove but may need more aggressive approach. A touch or swab of denatured alcohol on it in aninconspicuous place can help determine if it’s a paint related substance. That said, try working on the surface that will be covered by the new bumperettes. Maybe even some 1000 grit wet sanding and see if that gets any results, seems you want to clean up the edges so this white-ish stuff isn’t visible.
Old 11-05-2022, 02:14 PM
hard to tell from the pic but its probably the clear coat peeling
Old 11-05-2022, 02:29 PM
I realize it's a matter of personal taste, but the Euro bumperettes can be had for similar $$$ as the NA variants, and are lighter. If you're changing them for new ones consider Euro. It's an easy project to remove the bumper, plug weld the no longer needed holes, and respray the bumper.
Old 11-06-2022, 04:42 AM
917_Langheck's Avatar
Looks like hard water deposits. Try some CLR or hot distilled vinegar.
Old 11-06-2022, 07:22 AM
Troll Hunter
Nail polish remover on a Q-tip. Worth a shot.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 11-06-2022, 07:41 AM
Cairo94507's Avatar
Goof Off?
'71 914-6 #0372
'17 Macan GTS
Old 11-06-2022, 09:38 AM
Flat Six
Flat Six's Avatar
FYI, if it's original paint, should be single-stage -- no clear coat.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 11-06-2022, 10:17 AM
Really hard to say from the photo. I might try getting it with a clay bar, maybe goof off.
Can you share a source for these? I put my car back together and my US bumperettes are little better than trash. Definitely considering going with the Euro but don't want to spend $$$.
1982 911SC
Old 11-07-2022, 06:12 AM
