Suspension comparison
Old and new visual suspension comparison.
The Tarett sway bars were adjusted the following way: 1-5 [5=hardest setting] Front: 3.5 Rear: 4 The widebody/wide tires really bend the nearly stock suspension. It's even giving the current hardware a workout.
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) Last edited by flat6pilot; 01-10-2023 at 12:29 PM.. |
STOCK SWAY BARS AND 22/29 TORSION BARS
![]() TARETT ADJUSTABLE SWAY BARS AND 23/31 TORSION BARS
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
I've always loved your car, Kyle. I have to say, I'm a bit surprised that you were running 22/29 with stock sway bars with so much rubber under it. I always assumed you were running heavier torsion bars along with some form of aftermarket sway bars.
My skinny little '72 is running on 22/29 torsion bars and Tarret sway bars front and rear. I have my sway bars adjusted right in the middle on both ends. Shocks are red Konis adjusted 3/4 stiff. Handling is very neutral (for an old 911 anyway). It does work that suspension pretty hard, though. Here it is exiting 3A at Pacific. Tires are 205/60-15 AO48's:
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I know, I know...one hurdle at a time! Finally got around to updating the TB's and SB's last winter and the brakes to the Brembo kit. I think I should've went a little stiffer on the TB's. too. I need to get the shocks adjusted this Spring as well. I mean, it felt 'ok' in the car until I saw a pic of the lean! Wow! I figured I could improve the handling a bit.
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) Last edited by flat6pilot; 01-10-2023 at 03:27 PM.. |
