Do You Know or Can You Guess
I’m hoping to generate some interesting knowledge about 911’s. A posting of some we see and don’t know what it is about.
I have a good idea as to what this is and why it’s there. This a device to help prevent uncontrolled throttle advance when either the end of the car gets smooched. My engineer brain… Any other thoughts?
Reiver
Throttle cable
De Oppresso Liber Strength and Honor 5th Legion |
I think it's more rudimentary than that, though I could be wrong. The wider opening simply allows you to remove the pull rod from the bell crank pin. With the engine off pull that rod towards the front of the car and voila, it will come off the bell crank pin. It might come off in a rear collision, however if the hit is that hard I'm not sure if I'll be around to argue the point.
1978 Targa - 1980 3.0; Carrera intake; Megasquirt 2; EDIS ignition; 22/28 mm torsion bars and late Carrera sway bars; Carrera front brakes. Targa top rebuild in 2017. Suspension rebuild in 2019. Needs new paint and interior carpets. |
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
I believe it provides the travel needed by the cruise control. Without that loop, I'm guessing the cruise servo would push the entire throttle cable, including the accelerator pedal.
Although, if memory serves correctly, that same loop was in the early 911's, well before cruise was available. So, I may be all wet!
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
So you can tune carbs by opening and closing the throttle at the engine without moving the cable. And as mentioed, easy to remove.
Also, a good item to carry as a spare. Over the years I’ve heard of two failing on 912’s on various trips.
John W 1977 911S Targa with 3.0 |
Reiver
I agree...a bit of a safety device and easily removed for engine drops/maint etc.
De Oppresso Liber Strength and Honor 5th Legion Last edited by Reiver; 11-14-2022 at 06:51 PM.. |
Red Line Service
Your clutch cable is installed incorrectly. The bowden tube should be OVER the throttle bell crank!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
I agree, this is an older photo. I am still sorting out previous 39 years of mis-assembly. I took pictures of the clutch activation before I took everything apart. No contact with the bell-crank and have gentle curves.
