Clutch troubles part 2 (new symptoms)
UPDATE:
So tonight started with some disappointment.
Took car off jacks.
Engine off, everything shifts fine.
Engine on, everything grinds again.
Decide to start the car in gear. Car starts, it rolls, drive the car around for a while, car warms up, pull it back into neutral. Try going into gear, 1 and R grind still.
While driving the car around, tried to clutch in to see if it stops moving, car kept rolling happily.
Possibly something with the clutch plate and fly wheel being stuck / shift bushings / lord knows what.
The clutch cable should be properly adjusted since I did it (so I think) to factory spec.
What would make the car go in gear while off, and not go into gear while running?
All advice appreciated!
Old 11-15-2022, 06:35 PM
Sounds like clutch fork adjustment , or something is broken.
It goes into gear engine off because nothing is spinning
Engine running and everything is spinning
The clutch function is to stop all the spinning , disconnecting the engine from the input shaft of the trans and therefore stop it from spinning
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 11-16-2022, 06:07 AM
I’m starting to think it’s a stuck clutch plate, there’s no definite list of symptoms, but from others that have had it, I sound like them.
Old 11-16-2022, 06:16 AM
What year car?
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 11-16-2022, 06:32 AM
Originally Posted by JRSIII View Post
What year car?
1978 911sc
Old 11-16-2022, 06:33 AM
Ok never mind. I had a similar symptoms with a G50 that turned out to be hydraulic, but obviously that doesn't apply here.
_______________
John
Old 11-16-2022, 06:38 AM
Your clutch is not fully disengaged from the flywheel. That is the only reason it grinds. What was done in Part 1 of the episode?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-16-2022, 07:50 AM
you should consider the possibility of a broken fork that
engages the throwout bearing. One side of the fork cracks and
leads to all manner of clutch adjustment issues.
such as an inability to Keep the clutch adjusted it seems like
every time you touch it the adjustment has changed.
Scratched my head a long time on that one "81SC"
Give it a search
Old 11-16-2022, 12:50 PM
