What does it mean to "fit" a ducktail?
Hello all,
I'm wanting to add a ducktail to my 79'SC and was kinda wondering what it means to "fit" the ducktail. Is it adding or removing material or just adjusting where it sits on the hinges and stoppers?
Also, can you recommend a ducktail? I was leaning towards the TRE "HQ" version, the painting would be done by a bodyshop.
Thanks!
1979 911 SC Gran Prix White. Gone but not forgotten.
2016 GT4, current steed.
IG @hulley31
Old 11-17-2022, 10:44 AM
Behind the Sun
Means lots of body work, lot of hours, lots of dust
Go for a Stratton tail.
Made on a stock metal lid.
Your car deserves it
Old 11-17-2022, 10:48 AM
I'm good with tools.
AG81's Avatar
What 2.7RS said and a few curse words.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-17-2022, 11:05 AM
Thanks! I'll go look up the Stratton tail.
IG @hulley31
Old 11-17-2022, 11:10 AM
What it means is that you're getting a raw, fiberglass decklid that won't be exactly the right size and shape for your car. It will need to be shaved, added to, shaved, etc., by a professional before being painted. Could be that you get lucky and it fits great right off the bat, could be it needs a lot of work.
1982 911SC
Old 11-17-2022, 11:39 AM
Full Send Society
Any aftermarket fiberglass part, Stratton, TRE, Getty… is still going to need lots of work to get it perfect. Of course that’s a spectrum and for some, good enough is well, good enough. For others every gap must be precisely 3mm, no more, no less.
Don’t expect price to relate to the amount of work it’ll need to get it right. Even the most expensive part will still have to be made to fit your vintage car with all of its handmade nuances.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 11-17-2022, 12:58 PM
I bought an old fiberglass ducktail for my SC. It was made by Porsche Carousel (sp?) in Minneapolis many years ago, so I figured the fiberglass was cured. I used the Rennline adjustable hinges. Worth the price for the adjustability.
Old 11-17-2022, 02:31 PM
Reiver
Reiver's Avatar
Depends on the Duck tail...I bought mine on ebay years ago inexpensively and it fit very nicely with just a bit of sanding where it meets the body below the rear window. Has been in place for years and held up perfectly.
Did not require adjustable hinges just a few washers as spacers for height. Lucky I suspect but I think I paid 300 bucks.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-17-2022, 04:36 PM
My Stratton is currently being color matched and then it will be fitted. I’ll post a pic when complete.
Lucille my ‘85 guards red 3.2
Old 11-17-2022, 06:47 PM
ADDvanced's Avatar
IMHO it never looks right. Okay on a race car, always bugs me on street cars. The panel gaps and the small details just look terrible, almost every single time.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-17-2022, 08:06 PM
Slippery Slope Expert
Steam Driver's Avatar
And the whale tails, turbo tails, and tea trays DO look right on a street car? Particularly targas and cabs? I don’t think any of them look right. The duck tail is the most unobtrusive and tasteful of them all. IMHO.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 11-18-2022, 04:41 AM
Stratton Duck
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 11-18-2022, 05:17 AM
ADDvanced's Avatar
I just meant fit and finish wise. The surfacing under the 'duck' portion doesn't match up with the fenders/chassis of the car and it always looks odd to me.
Edit: Did this quick to explain what I mean. There's always this vertical surface on the side for no reason, it's like they tried to transition the ducktail surface back down to the chassis but just gave up.
Also, the surface under the ducktail, on the edge of the panel, is never G1 or G2 (tangent or curvature continuous) to the surfacing on the fender above the taillight, so you get this bumped up inflated 'bangle butt' look, along with a weird crease in the highlights where they come together.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-18-2022, 08:23 AM
Reiver
Reiver's Avatar
Well Porsche, when they first developed the DuckT, didn't think they'd be popular but they sold quickly when first displayed (Frere) and I've always liked the sporting look.
More importantly they work, all the 'tails' work as intended the Duck less than the huge ones but it is noticeably different if you have driven a slick tail and a DuckT in the 140 mph range (with an air dam up front)...much greater downforce and stability.
De Oppresso Liber
Old 11-18-2022, 08:49 AM
ADDvanced's Avatar
I'm derailing this thread, sorry.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 11-18-2022, 08:54 AM
7783911's Avatar
I did but a stratton and the fit was good, not excellent though the donor lid was my original. If I had to do again, I would have looked at the bolt on duck (smaller) that i ve seen discussed on this site
just an opinion and not a comment on Stratton ducks
Old 11-18-2022, 11:13 AM
Original factory duck
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-18-2022, 08:08 PM
No worries, I like reading your new thread on design, I don't disagree with you but I still like the idea of having a duck and switching out to the stock lid whenever I want to change the look.
IG @hulley31
Old 11-19-2022, 03:13 AM
The Stratton tail is very good, highly recommend it and have one on my car.
But they too are not perfect....mine ended up a couple of mm too long and because it is bonded on the edges, there was a limit to which I could adjust...hence the 1 mm too long.
Adjusting on top is a pain, as you need to balance between keeping the surfaces level and the gaps good, plus leaving enough clearance to let the hood open without hitting the engine bay lip.
Not hard, but fussy.....
D.
Old 11-19-2022, 04:48 AM
TKO TKO is offline
Custom one-off ...
Tom
IG@tomkearns
'94 WTL 964
Old 11-19-2022, 02:07 PM
