Missing hub thrust washer?
I took apart my driver's hub to replace the rotor and realized that there was no thrust washer installed. The bearing was directly sitting on the clamping nut.
Crazily, I haven't noticed any issues with the car. But now I've got the replacement rotor installed and I'm freaking out a bit about reassembling it without it. Is this the kind of part my local dealer would have in stock or is it more of an "order one" thing? Are they typically replaced when you swap in new bearings or re-used?
Old 11-19-2022, 06:08 PM
Reiver
Reiver's Avatar
Put the washer in place....you set the load on the bearing using the washer. It is a thick washer but you could source one just about anywhere if you had one to match it too.
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-19-2022, 07:00 PM
The proper thrust washer has a tooth that goes into the groove in the spindle, which keeps it from spinning, so you need the real one.
206 637 4071
Old 11-19-2022, 07:38 PM
Reiver
Reiver's Avatar
Forgot about that part.... luckily we have guys that do this for a living here...
De Oppresso Liber
Old 11-19-2022, 08:56 PM
Again, we need to know model year as there are 2 sizes of the thrust washer.
Old 11-19-2022, 09:26 PM
That T-washer also helps keep the grease packed in the bearing, in the bearing. While you can get the bearing pre-load adjusted properly w/o the washer, that's not the method for optimum longevity.
Old 11-19-2022, 10:00 PM
Mea culpa, it's an '81 SC. I believe it's part number 911 341 663 00. I've got one on the other side I could use as a template to create a new one from scratch, but I don't have the proper thickness of metal laying around. I have every intention of purchasing a new one, I just need to know if it's the kind of thing I can pick up without waiting at the dealer, or if I should order online.
My dealer won't open until Monday. I don't live in CA where you can pick one up from a junkyard same-day... Just trying to find the method which'll get me the washer the quickest.
Old 11-19-2022, 11:09 PM
H-viken's Avatar
Where do you live? With a bit of luck you’ll have another Pelican nearby who can help out
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 11-20-2022, 02:57 AM
66 911 #302694
Arctic Rat's Avatar
A new one is $7.........just order one?
My life is not a journey to the grave, with the intent of arriving safely in a pretty, well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaim .....
WOW WHAT A RIDE!!!!!!! reaperwear
Old 11-20-2022, 04:25 AM
