DSM DSM is offline
DSM's Avatar
Something I noticed. Rear 5.5 outer 17" was a bit wider than 16". The 16" didn't rub at all but the 17" did slightly. Had to set a bunch of negative camber to fix that. Think the the 17" tire has more to do with the rubbing as opposed to the slightly wider rim.
Old 02-06-2024, 08:01 AM
Hi DSM. Curious question. Are you running the factory 930
Spacers on the car with this setup?
Old 02-06-2024, 11:20 AM
DSM DSM is offline
DSM's Avatar
Please note:
Went with different sealant because it was easier to get.
Blue 77 930 is a US Spec (Came with 21mm front & 28mm rear spacers)
The New 17" BBS E50 run the 21mm front & no spacer in rear.
Old 02-07-2024, 08:14 AM
skinnerd's Avatar
Really looks great!
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 02-07-2024, 09:40 PM
Old post bump but does anyone know the size mounting hardware to run with these using the inserts? Thanks
Old 08-07-2025, 09:24 AM
Are you asking what size bolts are used to assemble the wheels? Surprisingly, call BBS and ask for E50 hardware. I just rebuilt mine and I was shockingly surprised how inexpensive it was to buy their hardware.
Old 08-07-2025, 09:57 AM
Yes I was referring to the hardware used to assemble the face to the barrel/lips. I'll have to give the a call. Also are the inserts pressed into the faces or is it just a simple slip fit?
Old 08-08-2025, 04:38 AM
The faces are not pressed in. They simply sit in the barrel. Its not a snug fit but there isnt much wiggle room, so you have to be careful not to scratch the barrels if you have alot of offset! My wheels I had to slide them in a good 4-5" I was worried id get scratch lines but didnt!
Old 08-08-2025, 07:19 AM
DSM DSM is offline
DSM's Avatar
Old 08-09-2025, 10:59 AM
DSM DSM is offline
DSM's Avatar
Old 08-09-2025, 11:16 AM
DSM DSM is offline
DSM's Avatar
Old 08-09-2025, 11:29 AM
