-   -   Re-sizing BBS E50 to 17" (http://forums.pelicanparts.com/porsche-911-technical-forum/1130330-re-sizing-bbs-e50-17-a.html)
DSM 11-22-2022 01:45 AM
Re-sizing these stunning BBS E50 to 17". OEM BBS parts on order....
Current Size: Front 16x8 (205 55 16) / Rear 16x10 (245 45 16)
Re-size: Front 17x9 (255 40 17) / Rear 17x11.5 (315 35 17)
http://forums.pelicanparts.com/uploa...1669112125.jpg http://forums.pelicanparts.com/uploa...1669112125.jpg
http://forums.pelicanparts.com/uploa...1669112125.jpg http://forums.pelicanparts.com/uploa...1669113804.jpg
IROC 11-22-2022 03:04 AM
That's beautiful! And some serious tire!
I did something similar. I re-sized my HRE Fuchs replicas and went from 8x16/9x17 (running 245/45-16s and 275/40-17s) to 8x17/9x17 but wimped out and am now running 225s/255s.
Shaun @ Tru6 11-22-2022 03:15 AM
Beautiful wheels and looking forward to the transformation. Are you still running factory spacers in the rear? I'm restoring a set of centers and have pieced together inner and out halves to make 7.5 front and 9.5 rear for the same tire size. But my rears are very deep and am pretty sure I will just have to remove the spacers to fit them in the arches.
Did you get all new hardware too? Source for everything?
DSM 11-24-2022 06:31 AM
No spacer on rear of blue 930. Will be using existing hardware and sealing ring. Will seal with Soudaseal 270HS. Used this sealant on the 18" OZ wheels. Worked perfect. The BBS E50 wheels are in amazing condition now, just want to size up. I like fitting alot of beef wellington under the arches.
This is where I ordered. They only accept wire transfer from USA. Anyone have experience with them? Wrong time to ask... I know. Order placed 10/11/22. Shipped 10/26 but was return to sender on 11/7. Hopefully this gets straightened out and parts arrive soon.
https://shop.felgen-renninger.de/
http://forums.pelicanparts.com/uploa...1669302468.jpg
http://forums.pelicanparts.com/uploa...1669302354.jpg
DSM 11-24-2022 06:49 AM
http://forums.pelicanparts.com/uploa...1669304833.jpg
Cory M 11-24-2022 10:03 AM
Dow Corning 832 sealant is readily available in the US from places like McMaster-Carr and is what is used by some wheel OEMs to seal 3 piece wheels. I've rebuilt a lot of wheels using it, following the recommended instructions, and I've never had one leak.
76dno 11-25-2022 05:43 AM
I believe you can buy the halves and hardware from BBS (Georgia)
DSM 01-01-2023 05:41 AM
These finally arrived last night. Happy new year to me!
http://forums.pelicanparts.com/uploa...1672583926.jpg http://forums.pelicanparts.com/uploa...1672583926.jpg
LJ851 01-01-2023 07:23 AM
Wow !
JakobM 01-02-2023 04:12 PM
Excellent post! - have a similar set of 16' E50's and planning same size 17' 9 & 11.5 for the 930. What is the combination used for the rim halves, inner and outer rim sizes to avoid the spacers?
DSM 01-07-2023 05:25 AM
Rear = no spacers on my 1977 930. Not sure about front. I added to inside only.
http://forums.pelicanparts.com/uploa...1673101391.png
DSM 01-07-2023 05:33 AM
Some pics of center and rear 11.5"
http://forums.pelicanparts.com/uploa...1673101615.jpg http://forums.pelicanparts.com/uploa...1673101615.jpg
DSM 01-07-2023 05:46 AM
For ref: 16x5.5 Outer Left & 17x5.5 Outer Right
http://forums.pelicanparts.com/uploa...1673102579.jpg http://forums.pelicanparts.com/uploa...1673102579.jpg
Geneman 01-07-2023 07:04 AM
These are simply beautiful DSM,... and look fab on your car.
Tell me, are you using the black rubber gaskets in ADDITION to the sealant? or sealant alone?
I have been assembling BBS E26 wheels for years now for a pure race car application using only then gaskets. never had a problem
thank you. FRank
DSM 01-10-2023 12:43 AM
thank you. FRank
Plan is to install large ring without rubber O-rings then seal. I’m sure the O-rings work but I prefer sealant.
onboost 01-10-2023 02:51 AM
Wheel update is beautiful! Should be stunning on that 930!
Now on another note.. the wife is gonna have your arse about car parts on her table! Lol!!
We all do that don't we!
DSM 03-12-2023 03:18 AM
http://forums.pelicanparts.com/uploa...1678619883.jpg
ljpviper 03-12-2023 07:15 AM
Wow beautiful
Nik0o0 02-05-2024 06:45 PM
Originally Posted by DSM (Post 11944748)
Hi DSM. Any updates regarding the BBS E50’s? Currently in the process of doing the same to mine and would love to see the end result
DSM 02-06-2024 07:42 AM
https://lh3.googleusercontent.com/dr...7Dwr7qNQ=s1600
https://lh3.googleusercontent.com/dr...mzBkEn_g=s1600
https://lh3.googleusercontent.com/dr...veUpC-dA=s1600
https://lh3.googleusercontent.com/dr...7c-wnwuw=s1600
https://lh3.googleusercontent.com/dr...TnZI_8Hw=s1600
DSM 02-06-2024 08:01 AM
Something I noticed. Rear 5.5 outer 17" was a bit wider than 16". The 16" didn't rub at all but the 17" did slightly. Had to set a bunch of negative camber to fix that. Think the the 17" tire has more to do with the rubbing as opposed to the slightly wider rim.
https://lh3.googleusercontent.com/dr...mLxH-hHQ=s1600
https://lh3.googleusercontent.com/dr...1HUaZSew=s1600
https://lh3.googleusercontent.com/dr...GMw452cA=s1600
Nik0o0 02-06-2024 11:20 AM
Hi DSM. Curious question. Are you running the factory 930
Spacers on the car with this setup?
DSM 02-07-2024 08:14 AM
Please note:
Went with different sealant because it was easier to get.
Blue 77 930 is a US Spec (Came with 21mm front & 28mm rear spacers)
The New 17" BBS E50 run the 21mm front & no spacer in rear.
https://lh3.googleusercontent.com/dr...9bbxkN3C=s1600
https://lh3.googleusercontent.com/dr...zbYD3xSA=s1600
https://lh3.googleusercontent.com/dr...TOQldjmG=s1600
https://lh3.googleusercontent.com/dr...U6gHKsRQ=s1600
https://lh3.googleusercontent.com/dr...51iBJv_c=s1600
https://lh3.googleusercontent.com/dr...oE5ckvVw=s1600
https://lh3.googleusercontent.com/dr...GIPwY4pw=s1600
skinnerd 02-07-2024 09:40 PM
Really looks great!
Badbiturbo 08-07-2025 09:24 AM
Old post bump but does anyone know the size mounting hardware to run with these using the inserts? Thanks
YellowBee69 08-07-2025 09:57 AM
Are you asking what size bolts are used to assemble the wheels? Surprisingly, call BBS and ask for E50 hardware. I just rebuilt mine and I was shockingly surprised how inexpensive it was to buy their hardware. http://forums.pelicanparts.com/uploa...1754589359.jpg
Badbiturbo 08-08-2025 04:38 AM
Yes I was referring to the hardware used to assemble the face to the barrel/lips. I'll have to give the a call. Also are the inserts pressed into the faces or is it just a simple slip fit?
YellowBee69 08-08-2025 07:19 AM
The faces are not pressed in. They simply sit in the barrel. Its not a snug fit but there isnt much wiggle room, so you have to be careful not to scratch the barrels if you have alot of offset! My wheels I had to slide them in a good 4-5" I was worried id get scratch lines but didnt!
DSM 08-09-2025 10:59 AM
http://forums.pelicanparts.com/uploa...1754765334.jpg
http://forums.pelicanparts.com/uploa...1754765430.jpg
http://forums.pelicanparts.com/uploa...1754766160.jpg
DSM 08-09-2025 11:16 AM
http://forums.pelicanparts.com/uploa...1754766410.jpg
DSM 08-09-2025 11:29 AM
http://forums.pelicanparts.com/uploa...1754767721.jpg
