'73 911 T Targa
How to remove these crimped hose fittings?
How can I remove these crimped connectors without scarring the tube to which they are connected?
These are the hard fuel lines that go up into the engine compartment.
I probably don’t have to mention that it’s tight quarters up in there.
Old 08-13-2024, 07:20 PM
Aircooled Breakfast
Dremel with a cutoff wheel. Cut a slot thru the collar and use a flat blade screwdriver to pry it open.
Old 08-13-2024, 07:29 PM
Yes, I used a cordless Dremel at real slow speed, slow and steady, cut a line lengthwise along the ridge portion if possible (lessens the chance of cutting through) just deep enough and thin enough so there’s a groove that the screwdriver can dig it and crack it open like a clam. Pliers can help peel away any stubborn portions.
Old 08-13-2024, 07:53 PM
Don´t cut anything. Just unbolt the other end of the hard line in the engine compartment, and remove the entire fuel line.
Thomas
1973 911S Targa 2.4
Old 08-14-2024, 01:23 AM
famoroso's Avatar
My uncle, Porsche factory trained master mechanic, owned an independent repair facility for 35+ years and cut countless (hundreds and hundreds) of these factory ferrules off and replaced them with German hose clamps (i.e. non-worm drive / fuel injection clamps).
Different location, same dynamic. I used a Dremel with a flexible shaft attachment...
Of course, the usual disclaimers apply, work in a well ventilated area, try and minimize sparks (slower cut-off wheel speeds) and have some type of fire suppression handy.
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 08-14-2024, 03:57 AM
