Cut out switch
Any suggestions of where I can splice in a simple on off kill switch?
Low amperage, behind the dash would be ideal. 85' 911 |
Uncertifiable!!!
Run the hot wire for the fuel pump to a standard toggle switch behind the top left corner of the passenger floor board then back to the fuel pump. Toggle switch is out of site and can be operated by reaching down just to the right of the accelerator pedal. There are lots of other locations under the dash as well to frustrate a would be thief.
M2CW Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Instagram.com/timofthevalley |
I used my mirror switch.
Toggle switch to break the brown ground wire at the DME relay under the driver seat. Mount wherever is convenient.
I put one in the trunk. It cuts power to the fuel pump. If I want to use that switch, I have to open the trunk, flip the switch hidden in the trunk, then lock the trunk with the key on the pull handle of my 85 Carrera.
So a thief would have to get into the locked trunk, and find the switch. Of course a pro will just tow the car and steal it anyway.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
