-   -   How to make my 911 sound like a v8?? (http://forums.pelicanparts.com/porsche-911-technical-forum/113048-how-make-my-911-sound-like-v8.html)
crashmy911 06-01-2003 06:37 PM
What can I do to make this thing sound mean? I have 74 heat exchangers on it now and just redid the top end. Two in one out exhaust. Thing sounds great when it it is above three thousand rpms but below this it sounds like a bug!!
SpeedracerIndy 06-01-2003 06:42 PM
Why would you want to make is sound like a V8? One of the reasons I fell in love with the 911 was becasue of the unmistakeable sound of the flat 6. It sounds more precise than a slopy American V8. There are many aftermarket mufflers that will change the sound.
Early_S_Man 06-01-2003 06:44 PM
Put a 2.25" crossover 'H' pipe and twin glasspacks or Supertrapps ...
dd74 06-01-2003 08:01 PM
Re: How to make my 911 sound like a v8??
Try this:
http://www.renegadehybrids.com/
It'll sound like a V8 afterward. ;)
RoninLB 06-01-2003 08:14 PM
did you ever consider a cam with big overlap, and higher compression pistons.. then the rest is easy.............Ron
masraum 06-01-2003 08:32 PM
take the muffler off or put on a 2 in 2 out flowmaster. It will then sound meaner
82SC 06-01-2003 08:58 PM
i ran SSI and dual out dansk on my SC engine...
hotrodders always asked me if I had a v-8 in there...really low growl/rumble
i prefer the stock sound with all the whirring and air-cooled noise
MJ
Jack Olsen 06-01-2003 09:36 PM
What Steve says. Flowmaster.
k9handler 06-01-2003 10:00 PM
install a 993 3.6 with nothing but the 993 cat...it will sound like a bigblock waiting to run the qtr! Ha Ha...I know this. If you would like I can post a link to a small video clip to show ya.
Milu 06-02-2003 01:36 AM
Install a mega stereo with volume control linked to your accelerator and play tapes of V8s ;)
Mikkel 06-02-2003 03:33 AM
Heh heh. Funny how this thread pops up right after I put a new exhaust on my 911. I've heard several 911s that sounded more like V8s and was ABSOLUTELY sure that I didn't want mine to sound like a V8!
Yesterday at Ring Knutstorp I met an american who drove a 944 Turbo. Being car nuts we talked about all things Porsche and he just couldn't understand all the fuss about 911s and their flat 6 aircooled sound!? I explained things for him and he responded that he considered a US V8 more sporty :rolleyes: So I just told him; the 911 is unique, the US V8s aren't. I must admit though that the Shelby Cobra replica that got us talking did sound *very* good :D
justinbaldwin 06-02-2003 03:57 AM
apparently you can buy a V8 conversion kit for $1,500, then all you need to do is drop in a V8 and you've got the real thing!
just a thought....
k9handler 06-02-2003 06:35 AM
Below is a link of my car at startup and idle.
www.threepointsix.com/new99304.avi
SmileWavy
Superman 06-02-2003 08:08 AM
The Triad exhaust I am using makes quite a low rumble below 3000 rpm. Above 3000 rpm, it sounds like an F1 car. It has essentially what Warren suggests. It has a fat expansion/resonance chamber that collects exhaust from both sides of the engine. This improves low end torque and also produces that deep, hollow sound I have always associated with drag cars. That same sounds was also present when I was running with a hollow CAT.
dd74 06-02-2003 08:12 AM
Hey Jim: I received the Triad Friday. Plan on installing it this week. What a beautiful piece of artwork. Weighs only 21 pounds, too. :)
1fastredsc 06-02-2003 08:16 AM
What's a triad exhaust? And logic would tell me that if you want a 6 to sound like an 8, add two cylinders. :)
jmz 06-02-2003 08:23 AM
on the flow masters, are people modfying a bursch or sebring exhaust? or is there a 2 in 2 out flowmaster that can be bought off the shelf?
KTL 06-02-2003 08:49 AM
Flowmaster people are having a shop custom bend the pipes to fit a Flowmaster crossover muffler.
There are two versions of this muffler.
Single-in, dual-out unit is Flowmaster part # 42583. Inlet and outlets are 2-1/2 in. dia.
Dual-in, dual-out unit is Flowmaster part # 42582. Inlets and outlets are 2-1/2 in. dia.
Dynomax also makes this muffler size/configuration in varying materials. They come in UltraFlo welded, UltraFlo SS (stainless steel), and SuperTurbo. The SuperTurbo is priced about the same as the Flowmaster (around $70something from Summit Racing). The UltraFlo's are around $150 and a little sturdier.
UltraFlo SS:
#17266 = 1 in, 2 out, 2-1/2 in. dia.
SuperTurbo:
#17725 = 2 in, 2 out, 2-1/4 in. dia.
#17739 = 1 in, 2 out, 2-1/2 in. dia.
UltraFlo Welded:
#17231 = 2 in, 2 out, 2-1/2 in. dia.
edit: don't use this #17231 muffler! The 17231 is not a crossflow design. It's a same side in / same side out design as shown here:
http://forums.pelicanparts.com/uploa...1074458652.jpg
The same goes for the #17276, 17280 (straight thru design, not crossflow) UltraFlo SS mufflers. Not a good application for SSI's as it's too wide and won't work well:
http://forums.pelicanparts.com/showthread.php?s=&threadid=138386&perpage=20&highl ight=flaumeister&pagenumber=2
Superman 06-02-2003 08:59 AM
Out of respect for (and not just fear of) Wayne and his magical BBS, I want to be careful not to 'sell' the Triad exhaust here. The owner of Triad is a personal friend. The website is
www.triadwestperformance.com
It's a good product for a good price. I'd like to see Pelican carry it.
I'm glad you like the Triad exhaust so far Dave, but to be fair we should probably reserve final judgment until after it's attached to the car. Good luck with the installation, it should be easy.
dd74 06-02-2003 09:57 AM
Thanks, Jim. And yes, you're correct about "the sell" addage and the BBS. My apologies to Wayne.
As for the Bursch, I don't think it can be modified in any way to be a "dual out." There isn't enough room on the right side of the muffler for such a modification.
