-   -   MFI injector adapter (http://forums.pelicanparts.com/porsche-911-technical-forum/1131111-mfi-injector-adapter.html)
shahram 12-07-2022 01:38 PM
I finally found the time to rebuild my 2.4 MFI engine. I plan to upgrade the engine with few modern components, a programmable ECU and injectors but i would like to keep the stacks and the MFI.
Does anyone know of an adapter which could be used to install newer injectors in the original 2.4 heads?
http://forums.pelicanparts.com/uploa...1670449115.jpg
mb911 12-08-2022 01:15 PM
I know of them and waiting on my set. As soon as I get back in contact with him I will let you know if he has anymore. He currently is MIA
shahram 12-08-2022 01:31 PM
Thanks Ben, would really appreciate it if you could get back to me when you have received your set.
mb911 12-08-2022 01:38 PM
I am hoping I hear from him soon
RSTarga 12-08-2022 04:42 PM
A bit confused, you are keeping MFI but using a programmable ECU?
Jonny042 12-08-2022 05:01 PM
User jpnovak on here (also on IG as @Classicautowerks) makes and sells them. He should be easy enough to get in touch with.
mb911 12-08-2022 05:05 PM
Yes he does and typically yes easy to get in touch with. I just have not been able to reach him for a bit . He was sending mine out but there was a delay I am assuming to his real job.
mb911 12-08-2022 05:07 PM
MFI throttle bodies with injectors into the heads for fuel
shahram 12-09-2022 01:01 AM
Thanks all, i jest sent Jamie an email, i hope he replies soon.
mb911 12-09-2022 03:15 AM
Sounds good. Please update us.
BoxsterGT 12-22-2022 09:34 AM
We did this years ago on a 71 S motor built to 2.5 Ltrs.....
http://forums.pelicanparts.com/uploa...1671729945.JPG
using Megasquirt.
I may have a few Injector adapters here somewhere. I will look in my storage trailers.
I planned to do another at some point, as this ran well and was exciting to drive.
http://forums.pelicanparts.com/uploa...1671730340.JPG
Len
shahram 12-22-2022 12:29 PM
Hi Len, i sent you a pm a while ago. I really would appreciate it if you could contact me. I need a set of the injector adapters for my build. Thanks
mb911 12-22-2022 02:40 PM
I got part of my setup in . Waiting on the adapters but Jamie sent them out so waiting on the mail.http://forums.pelicanparts.com/uploa...1671748767.jpg
