shahram's Avatar
MFI injector adapter
I finally found the time to rebuild my 2.4 MFI engine. I plan to upgrade the engine with few modern components, a programmable ECU and injectors but i would like to keep the stacks and the MFI.
Does anyone know of an adapter which could be used to install newer injectors in the original 2.4 heads?
Old 12-07-2022, 01:38 PM
I know of them and waiting on my set. As soon as I get back in contact with him I will let you know if he has anymore. He currently is MIA
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-08-2022, 01:15 PM
shahram's Avatar
Thanks Ben, would really appreciate it if you could get back to me when you have received your set.
Old 12-08-2022, 01:31 PM
I am hoping I hear from him soon
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-08-2022, 01:38 PM
A bit confused, you are keeping MFI but using a programmable ECU?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-08-2022, 04:42 PM
(man/dude)
Jonny042's Avatar
User jpnovak on here (also on IG as @Classicautowerks) makes and sells them. He should be easy enough to get in touch with.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 12-08-2022, 05:01 PM
Yes he does and typically yes easy to get in touch with. I just have not been able to reach him for a bit . He was sending mine out but there was a delay I am assuming to his real job.
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-08-2022, 05:05 PM
MFI throttle bodies with injectors into the heads for fuel
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-08-2022, 05:07 PM
shahram's Avatar
Thanks all, i jest sent Jamie an email, i hope he replies soon.
Old 12-09-2022, 01:01 AM
Sounds good. Please update us.
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-09-2022, 03:15 AM
BoxsterGT's Avatar
Porsche Crest
We did this years ago on a 71 S motor built to 2.5 Ltrs.....
using Megasquirt.
I may have a few Injector adapters here somewhere. I will look in my storage trailers.
I planned to do another at some point, as this ran well and was exciting to drive.
Len
Old 12-22-2022, 09:34 AM
shahram's Avatar
Hi Len, i sent you a pm a while ago. I really would appreciate it if you could contact me. I need a set of the injector adapters for my build. Thanks
Old 12-22-2022, 12:29 PM
I got part of my setup in . Waiting on the adapters but Jamie sent them out so waiting on the mail.
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-22-2022, 02:40 PM
