Fuchs Date Stamp ?????
OK, I know the 911.362.020.10 is the part number but which of the other numbers is the date stamp?
Actually what do all the other numbers mean? Thanks
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
The date stamp is a rubber stamp with ink that is easily obliterated.
The Fox head is "Fuchs" in German. The "AS1.62" is the alloy used. See below: A: We used 6082(USA), 3.2315(DIN), AlMgSi1(Type) or FUCHS Designation AS10.62, .62 indicates Temper Disignation. Best regards Joachim Boehme EN AW-6082, 3.2315 typical mechanical properties 0,2% Yield strength Rp 0,2 240-310 MPa Ultimate tensile strength Rm 250 MPa Elongation A5 8-10 % Hardness 91 HB physical properties Density 2,7 g/cm� good welding properties very good anticorrosion properties good anodizing properties good drilling and turning properties alloy: AlSiMgMn (former AlMgSi1) Temper: T651 stress relieved by stretching ,heat-treatable Composition %: Al 96.5, Mg > 0.64, Si > 0.7
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Wow, now there is some technical information!!
Thanks a bunch. So when folks talk of their date stamped Fuchs, they are just lucky enough to still have the ink stamp still present and not worn off?
abit off center
My 14" fuchs on the 69 are punched stamped 3 68 near the hub on the inside
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Here's where the date code is stamped on most Fuchs wheels :
Andy M&W 904 ... now gone GT-style 356C ... also gone |
Just look at the above pic. The date is stamped into the spoke center. It is a stamp and does not rub off.
Easy to find now that I know where to look.
Thank you for your help.
Hi,
I was curious about some wheels I recently acquired. Using the above stamping location, the numbers I have appear to be 7267. I will say that the first and last 7 are oddly shaped and deeply stamped, while the 2 & 6 appear to be normal in shape yet not as deeply stamped. Thoughts? Thanks, HB
Current: 1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun! 1971 911 T Targa Signal Yellow (summer joy) Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green |
I have a set of Fuchs which all have the same stamps:
"4 1/2J x 15" "fox stamp" 25205.3 901.361.012.01 I can not find a date stamped or any other stamping anywhere. Is it safe to assume the date was originally in ink? Do these wheels have serial numbers? |
911 carrera 3.2 (1985)
Fuchs stamps 7Jx15 (incl. date pic 4285)
![]() ![]() ![]() ![]() ![]() ![]() Kees. |
What is the number in the square box after part number,
I have seen 10, 41, 44, 45 Is the Offset printed anywhere? |
I have a few old to share pix as well.
![]() ![]() ![]() ![]() [img]http://forums.pelicanparts.com/uploads26/10000075181671664443 ![]() ![]() ![]() ![]() ![]()
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
