Fuchs Date Stamp ?????
OK, I know the 911.362.020.10 is the part number but which of the other numbers is the date stamp?
Actually what do all the other numbers mean?
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 04-20-2007, 07:58 AM
304065's Avatar
The date stamp is a rubber stamp with ink that is easily obliterated.
The Fox head is "Fuchs" in German.
The "AS1.62" is the alloy used. See below:
A: We used 6082(USA), 3.2315(DIN), AlMgSi1(Type) or FUCHS Designation AS10.62,
.62 indicates Temper Disignation.
Best regards Joachim Boehme
EN AW-6082, 3.2315
typical mechanical properties
0,2% Yield strength Rp 0,2 240-310 MPa
Ultimate tensile strength Rm 250 MPa
Elongation A5 8-10 %
Hardness 91 HB
physical properties
Density 2,7 g/cm�
good welding properties
very good anticorrosion properties
good anodizing properties
good drilling and turning properties
alloy: AlSiMgMn (former AlMgSi1)
Temper: T651 stress relieved by stretching ,heat-treatable
Composition %: Al 96.5, Mg > 0.64, Si > 0.7
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-20-2007, 09:08 AM
Wow, now there is some technical information!!
Thanks a bunch.
So when folks talk of their date stamped Fuchs, they are just lucky enough to still have the ink stamp still present and not worn off?
Jung
'68 912 Coupe
'82 SC sunroof
Old 04-20-2007, 10:53 AM
304065's Avatar
Yes, lucky. Particularly for the wheel of a car.
fuch originality questions...
'81 R65
Old 04-20-2007, 11:03 AM
abit off center
cgarr's Avatar
My 14" fuchs on the 69 are punched stamped 3 68 near the hub on the inside
______________________
Craig
G2Performance
Old 04-20-2007, 11:07 AM
Here's where the date code is stamped on most Fuchs wheels :
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 04-20-2007, 01:53 PM
Just look at the above pic. The date is stamped into the spoke center. It is a stamp and does not rub off.
Old 04-20-2007, 03:35 PM
Easy to find now that I know where to look.
Thank you for your help.
Jung
'68 912 Coupe
'82 SC sunroof
Old 04-20-2007, 04:30 PM
JV44HeinzBar's Avatar
Hi,
I was curious about some wheels I recently acquired. Using the above stamping location, the numbers I have appear to be 7267. I will say that the first and last 7 are oddly shaped and deeply stamped, while the 2 & 6 appear to be normal in shape yet not as deeply stamped.
Thoughts?
Thanks,
HB
Current:
1990 964c2 Grand Prix White: lowered, Big Reds, Big Fun!
1971 911 T Targa Signal Yellow (summer joy)
Past cars: 1970 911T Yellow, 1983 928, 1972 911 Targa emerald green
Old 11-10-2011, 12:53 PM
I have a set of Fuchs which all have the same stamps:
"4 1/2J x 15"
"fox stamp"
25205.3
901.361.012.01
I can not find a date stamped or any other stamping anywhere. Is it safe to assume the date was originally in ink? Do these wheels have serial numbers?
Old 11-26-2011, 07:13 AM
911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Fuchs 7Jx15 front wheel
Fuchs stamps 7Jx15 (incl. date pic 4285)
Kees.
Old 11-26-2011, 07:57 AM
What is the number in the square box after part number,
I have seen 10, 41, 44, 45
Is the Offset printed anywhere?
Old 12-21-2022, 01:28 PM
I have a few old to share pix as well.
[img]http://forums.pelicanparts.com/uploads26/10000075181671664443
Old 12-21-2022, 02:19 PM
