Radio anomaly
Hello,
You guys probably see me around the forum as the radio guy that for the past 15 years have reunited many original radios with their rightful cars.
I like to take pride in what i do, but for once Im stumped on a radio installation.
So i have an 85’ 911 carrera. I had a blaupunkt charleston installed, removed the Charleston in favor of the Blaupunkt Reno.
Well, the Charleston worked great. However, When i connect the Reno, the radio in the car does not power on. I took a multimeter, the positive wire is not delivering 12v to the radio when connected. When the radio is not connected, I have 12-13v power to the wire.
I dont get it. I bench tested the reno, works well. But when I connect it in the car its not getting power. Somewhere along the way there is a bad connection or possible short?
I cant track it down. I have another radio laying around, it powrers on fine in the car
Loosing my mind.
Oh and i tried both power wires one from battery and one from ignition.. nothing
Old 12-22-2022, 03:08 PM
First, I find that a single shot of bourbon to be helpful in these situations...
Next, does the radio power up and work fine on the bench? I think you said yes, but just double checking.
How are you determining that there is no power to the radio when connected?
I'd try connecting only the power wires...disconnect all the speaker, antenna and other wires from the radio harness and just focus on getting the radio to power up.
Old 12-22-2022, 03:17 PM
A grounding problem?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-22-2022, 03:43 PM
Lol, oh I had a beer (or 2) to calm the nerves
Radio works perfectly on the bench. I literally connect an old blaupunkt richmond with the car wires and it powers on. I unplug the radio, plug in the reno. No power coming in
I determine there is no power going to the radio with a multimeter. Not getting voltage to the radio positive terminal
Yes, only concentrating on power wires. Both ignition and battery positive wire. Speakers/antenna unplugged
Old 12-22-2022, 03:51 PM
Ok
Ground ok. Its like there is a power drain.. fuses looked good.. im
Stumped.. dont wnat to start digging to deep, tracing the wire back tonthe battery
Old 12-22-2022, 03:54 PM
Test
So you guys dont think im crazy.
The 1st radio (richmond) powers on with 2 wires.
The 2nd radio (reno). Does not. Same 2 wires connecting the radio
M
VS
Old 12-22-2022, 04:00 PM
Probe a test light into the suspect radio feed wire. Make sure you have a known good ground connection.
With no radio connected and power on, is the test light normal brightness?
Connect radio and repeat test.
If the bulb dims then there is a bad connection somewhere between the test light and power supply point.
Old 12-22-2022, 04:02 PM
Dont have a test light probe.. will have to get one
Old 12-22-2022, 04:08 PM
Been here a while
Analog radio only needs switched power. Digital radio needs constant power for memory in addition to switched power. Won’t power on without both power feeds.
looking for 1972 911t motor XR584, S/N 6121622
Old 12-22-2022, 04:19 PM
Reno, doesnt need constant power
Just ground, switched power positive and display illumination
Old 12-22-2022, 04:35 PM
Been here a while
The manual makes it pretty clear that constant power is required. As is switched power. I find it hard to believe any digital radio doesn’t need both constant and switched power.
Old 12-22-2022, 04:58 PM
I hooked it up the same as this guy in the video
https://youtu.be/76qxTJKV9WQ
Old 12-22-2022, 05:22 PM
Solved
Problem solved.
Weak ground wire. It was strong enough to power on one radio but not the other
Got a fresh ground, works great
Old 12-23-2022, 06:46 AM
