g96/g97 transaxle in a aircooled
anybody here have done the conversion?
Old 12-17-2022, 11:15 AM
gearhead
The crankcase bolt pattern is different. To my knowledge nobody has made an adapter plate to suit. The challenge is that the starter is on the engine on the m96, whereas it’s on the gearbox on anything air cooled.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-17-2022, 12:32 PM
the pattern is different except for turbo engine, metzger share aircooled pattern.
Old 12-17-2022, 01:08 PM
gearhead
The GT3 gearboxes all bolt right up, and are 2 wheel drive. Turbos are awd. Plenty of people have done that conversion on race cars.
1974 914 Bumble Bee
2009 Outback XT
Old 12-17-2022, 01:30 PM
Looked into this briefly for my '81. Things that come to mind:
1) Bolt pattern only correct on the expensive models
2) Transaxle mounting points wrong
3) Torsion tube interference
4) Hump between rear seats too small
5) Cable vs hydraulic clutch
6) Sensors
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 12-17-2022, 06:03 PM
gearhead
Correct. Budget $25-40k to do it. That’s why I thought maybe he was asking about the g96.00/01 Carrera gearboxes, which is a $2500 gearbox.
1974 914 Bumble Bee
2009 Outback XT
Old 12-17-2022, 06:22 PM
Don't forget too that the shifters are entirely different. Cables on the G96, rod on the earlier cars. And the pedal box and associated parts if you're going from cable clutch to hydraulic.
I have a 996 GT2 in the garage sitting next to the G-body. I've eyed this conversion for years. If you have mad metalworking/fabrication skills, much of it wouldn't be too difficult, but the cost of the gearbox itself and all of the conversion parts really adds up quickly. The G96 trans is a LOT longer than a 915 when you set them side by side.
By G96, I assume the OP meant G96/50, /88, or /90. The G96/01 has a different bolt pattern and won't bolt on, along with the starter mounted on the engine instead of the transmission. They simply won't fit.
Old 12-18-2022, 07:26 AM
Matt, are you still working on the sequential 915 conversion (I thought I had read that somewhere)? If so, my guess would be the cost would be in this same ballpark for a plug and play solution?
Bill
Old 12-18-2022, 08:59 AM
Bill Verburg's Avatar
It would be hard enough to fit a g50/01 into a pre '87 911
but w/ enough $ and skill anything is possible
Bill Verburg
Old 12-18-2022, 09:50 AM
gearhead
Bill
Covid has temporarily put the project on the back burner. Until we see some normalcy to steel availability and inventory levels, it will simmer for a bit.
There is a Holinger sequential solution for these cars. Jerry Woods installed one for a customer, and did it with hand controls. I don’t know what it cost, but $40-50k would be my guess.
1974 914 Bumble Bee
2009 Outback XT
Old 12-18-2022, 09:51 AM
Racer
winders's Avatar
Are you using the whole 915 case or are you using just the bell housing and using custom gear housing and cover?
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-20-2022, 06:29 PM
Armed Bastard
djb25's Avatar
How are the g96.00/01 gearboxes?
Would it be a worthwhile upgrade for a pre-g50 car, purely from a gearbox perspective (ignoring the difficulty of the conversion)?
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 12-23-2022, 06:17 AM
Racer
winders's Avatar
Those gearboxes don’t fit on Mezger (air-cooled) engines.
Scott Winders
PCA GT3 #3
Old 12-23-2022, 08:41 AM
kevingross's Avatar
Weighs more, wrong gearing, bloody difficult to service, unknown costs to adapt the G96 to your car... sounds like a great idea!
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 12-24-2022, 09:50 AM
It's a 914 ...
stownsen914's Avatar
Are aftermarket gear ratios available that fix a g96 box?
Old 12-24-2022, 01:51 PM
G96/01 simply won't fit. Don't know how many times we need to say this.
The 3.4L has an entirely different bellhousing, with the starter mounted to the engine.
The Mezger engines have a round bellhousing with the starter mounted to the transmission.
Old 12-25-2022, 10:38 AM
It's a 914 ...
Using that logic, you can't put a Hewland on a Porsche engine either. I guess it would take a LOT of work. Saw a Cup Car sequential box on a 914 recently.
Do g96 boxes share gearsets with any other Porsche trannies like G50?
Old 12-25-2022, 12:24 PM
im will be using a 997 turbo tranny i am curious what are people doing for hydraulic clutch pedal
Old 12-25-2022, 12:51 PM
Racer
winders's Avatar
If you are going through the effort to put that gearbox in an air-cooled car, you might as well get rid of the pathetic Factory pedal cluster and get a Tilton 800 series cluster with hydraulic clutch setup.
Scott Winders
PCA GT3 #3
Old 12-25-2022, 01:13 PM
Racer
winders's Avatar
Like this:
Scott Winders
PCA GT3 #3
Old 12-25-2022, 03:44 PM
