Question Transmission problem
1981 911 SC
all of a sudden I have trouble getting the shifter into first & reverse. With the clutch pedal to the floor the reverse gears are still spinning.
Does anyone know where to start?
Is it the synchros? or as I believe a bad clutch or just out of adjustment.
I would appreciate all comments
Tx!
john
Old 06-03-2003, 03:12 PM
Original Owner
tsuter's Avatar
Well can you with the car stopped and motor running push in the clutch and shift into second and drive?
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 06-03-2003, 03:21 PM
YESIREE!
Old 06-03-2003, 03:24 PM
Unregistered
sammyg2's Avatar
My first guess would be a combination of worn shift bushings and shift linkage adjustment, but that's all it is, a guess.
Whith the car stopped (engine off) can you get it into first, and if so, how much can you move the shift knob back and forth and side to side?
Old 06-03-2003, 03:29 PM
Original Owner
tsuter's Avatar
That likley rules out the clutch problem and points to 1st and reverse sychros and all the other things that can go bad in the 915 transmission.
tsuter
Thaaaats Right!!
Old 06-03-2003, 03:31 PM
Original Owner
tsuter's Avatar
I had the entire rubber center of the shift coupler rip apart. That is easy to check. It is under the panel in the center back seat.
tsuter
Thaaaats Right!!
Old 06-03-2003, 03:43 PM
