Tony
Maxhouse97's Avatar
Best place to buy a used engine?
Looking for a used 3.0 motor to buy and rebuild in anticipation of a future roller purchase. Where is the best place to find one? Pelican ads, Facebook marketplace, Hershey parts swap, etc? Also anything I can do to prevent buying a lemon, similar to a PPI for a full car? Thanks.
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 12-30-2022, 04:11 PM
The 9 Store
Yes, all those places. If you start to read up and watch videos on how to rebuild an engine, it will help you learn how to do your own ppi or at least what to look for. Buying a core engine that needs a full rebuild is more about knowing what to pay for it than knowing what’s wrong with it. Other than buying an engine that’s blown up inside, you are pretty much counting on refinishing, repairing or replacing everything that normally gets done in a rebuild.
If you are thinking that overhauling an engine and buying a roller will save you money over a good running car, you might be surprised.
All used parts sold as is.
Old 12-30-2022, 04:37 PM
Under the radar
Trackrash's Avatar
Beside price, unless you have test driven the motor, even then, I would do a leak-down test. If it fails, call it a core, and negotiate.
Look underneath at the cylinders. You want Mahles, a good chance they may be still in spec and reusable.
I would want a COMPLETE motor. Distributor, fan and shroud, exhaust, and flywheel.
Shop around. I once looked at a motor that "a German guy rebuilt it". I looked in the intake port and there was carbon on the valve. It was also missing the fan, shroud and alternator. I told him good by. Basically the motor was worth zero.
Edit: Just saw this on FB. Might be worth a look. https://m.facebook.com/groups/240974066679363/permalink/1327041181405974/?mibextid=lURqYx
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-30-2022, 07:17 PM
Tony
Maxhouse97's Avatar
Wow that’s a great find, thanks Gordon. Unfortunately I’m not ready to pull the trigger but that seems like a great catch. I dislike normal FB but need to learn how to navigate it to find deals like this.
Good points on the motor, yes I would want a complete one as buying the incremental parts is expensive. Ideally it would be a motor out of a car that had a top end rebuild need, or one that someone was removing to move up to a 3.6.
Tony
22 GT4
04 E46 M3
Old 12-31-2022, 05:45 AM
Well said. Agree with this 100%
Old 12-31-2022, 06:44 AM
Registered Minimalist
75 911s's Avatar
Mepstein is actually a really good source! He has solid deals nearly every month on air cooled engines. I would also say the last two air cooled flat six motors I bought, I bought from friends!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-31-2022, 06:57 AM
Banned
Forget the 3.0, get a 3.6 Metzger motor.
1. The provenance cool factor is better
2. The value curve for a 3.6 is better than a 3.0
3. 100 HP more is the clincher.
Old 12-31-2022, 07:30 AM
75 911s's Avatar
^well yeah, but literally 3X more expensive. Can find a good core 3.0 for 8-10k. A core 3.6 is low 20s typically. The 3.6 is 25 years old too, so probably needs a refresh.
Old 12-31-2022, 08:18 AM
Tony
Maxhouse97's Avatar
Ha Ted I hope more people think like you do so they remove their 3.0s for 3.6s
Tony
22 GT4
04 E46 M3
Old 12-31-2022, 08:23 AM
The 9 Store
I have a low mileage 95-993 for $30k and a good running 3.2 for 18,500. If you buy a 3.0 for 10k, it’s very easy to put another 10-15k into rebuilding it. That’s doing it yourself. Unless a friend gives you a gift, the 3.0 core for 10k will be a core, not a good running engine that needs a light top end. That’s just the market today.
This isn’t an ad for my stuff, just a reminder that buying the best Porsche car and parts that you can afford is usually the most economical way to do it.
Old 12-31-2022, 08:36 AM
Banned
I started by staring @ broken 3.0 head studs but had a 3.0 core to sell as offset.
The 964 & 993 bottom ends are well designed and will go a long time. A used 3.6 with a fresh top end and big oil cooler was a fair compromise reliability scenario and biggest bang for my bucks.
8 years of track use in club TT so far.
Old 12-31-2022, 09:17 AM
2nd mepstein
My 82 in my 77 still running strong.
He still has some supply I believe.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 01-01-2023, 07:57 AM
Slow911's Avatar
what is mepstein ? website ?
PCA-Chgo
1970 911t
Old 01-02-2023, 09:32 AM
Grappler
Rodsrsr's Avatar
See post #2 send him a PM.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-02-2023, 11:42 AM
Been here a while
79 3.0
I’ll have a 79 3.0 that I’ll be removing soon. It will be in SoCal out of the car a month from now
10 years ago, and just 10,000 miles ago, one of the best shops in the northeast, automobile associates in canton CT did a top end rebuild, head studs and more. I have all the documentation and I’ll be able to provide you with compression and leak down numbers and any photos or videos you might be interested in.
looking for 1972 911t motor XR584, S/N 6121622
Old 01-02-2023, 01:24 PM
I have one and it is ready to ship to you.
Ed Muscat. San Diego
Old 01-02-2023, 02:42 PM
I’ve had success on Blue prism automotive used engines new york and eBay Motors for used engines, especially if you're willing to wait for the right deal. To prevent buying a bad engine, request service records, compression test results, and try to buy from reputable sellers. If you can inspect it yourself or have someone local check it out, that’s ideal.
Old 10-16-2024, 09:57 AM
The 9 Store
Since my name was mentioned again, I currently have a rebuilt 3.2, Pauter rods, Elgin sport cams, harness & Ecu for 32,500. We had it in a customers car for a show, ran it about 200 miles. It’s a good bit stronger than one with 964 cams but still very drivable at low rpm’s. Made the wide body Carrera feel lively and fun.
I have a Peter Dawe rebuilt Carrera trans with factory cooler with the engine. That will add 9,500 to the engine price. Shifts better than new.
Old 10-16-2024, 11:24 AM
